Torque pro pid help
Old Mar 6, 2017 | 05:07 PM
onequicksportster's Avatar
onequicksportster
Torque pro pid help
Does anyone have the correct pids for torque pro for 2015 f250 6.7?
I have found a few for 2011- 2014 or so, but eot, ect, and dpf regen on and off and amount of soot don't work on my truck.. Actually the only ones I could get to read were rpm's and the tire pressure pid's.. Thanks in advance..
Old Mar 6, 2017 | 05:57 PM
djousma's Avatar
djousma
Download, install, and import these into torque pro
Old Mar 6, 2017 | 06:29 PM
onequicksportster
Thank you!!! I will try that in the morning when I get off work..
Old Mar 31, 2017 | 03:10 PM
thewestie's Avatar
thewestie
How did it work for you?
Old Mar 31, 2017 | 08:18 PM
onequicksportster
oops sorry I forgot to get back.. Yes most of them worked, but dpf percent and regen on and off still don't.. Oil temp works, but ect don't.. they don't even show up to pick from.. Not sure what I'm doing wrong..
Old Mar 31, 2017 | 10:33 PM
sdetweil's Avatar
sdetweil
note that the list is alphabetical.. which is a pain in the butt...
Old Apr 1, 2017 | 03:42 AM
onequicksportster
I've been all through them.. Still cant find them. Maybe I have to be hooked up to wifi when I'm searching and picking them to make gauges ..
Old Apr 1, 2017 | 06:30 AM
sdetweil's Avatar
sdetweil
ECT1 should be 'Engine Coolant Temperature ECT 1 6.7L" from the sheet in the plugin.. and ECT2 is "Engine Coolant Temperature ECT 2 6.7L"
what else doesn't show up?
I am the plugin maintainer
Old Apr 1, 2017 | 06:56 AM
sdetweil's Avatar
sdetweil
I just downloaded and re-installed the plugin, and all the entries in the list are loaded on my samsung tablet.
Old Apr 1, 2017 | 07:51 AM
snickers104's Avatar
snickers104
I got mine to work....but I don't think the soot level is correct....goes way above 100 percent sometimes.
Old Apr 1, 2017 | 07:52 AM
thewestie's Avatar
thewestie
I'll give it a shot today. I'm struggling with the whole thing.
Old Apr 1, 2017 | 07:53 AM
sdetweil's Avatar
sdetweil
I haven't made any year specific PIDS. that may be required..
Old Apr 1, 2017 | 10:46 AM
gwg42's Avatar
gwg42
I have torque pro on a tablet. Has there been any changes/additions to the pids. It's been over a year +- since I have downloaded. Going on a long trip this summer. My soot levels does not match my trucks screen, but regen on/off is correct. I might go up to the 130's before a regen kicks on, and the low soot number never really matches. But after a while of watching both, there is a good correlation. So the differences don't bother me.
I really like my screens and enjoy watching all the data.
Old Apr 1, 2017 | 11:30 AM
sdetweil's Avatar
sdetweil
three have been no changes in the last 18 months..
you are also in that category 2015 and up where some algorithms appear to need adjusting.. I jut haven't seen a confirmed change in the PIDS forum..
Old Apr 1, 2017 | 03:23 PM
MPD56's Avatar
MPD56
Hey Sam
Just to ADD.
My 2013 readings don't match the dash either. And my Torque Pro PID doesn't match the the started and stopping at 0% and 100% after a PCM update. There is a few resasons for different model years to not match, one examples is that some uses different sensors and the Soot Levels are really just a equation of the back pressure in the DPF. I have changed the equation for my 2013 and friends 2015 Soot% but haven't had time to verify it and when I do, I will post it.
