Oil temp... Sender?
Old Mar 6, 2017 | 11:48 AM
christaylor's Avatar
christaylor
Oil temp... Sender?
Ever since having the EGR delete done, the oil temp has been LOWER than the coolant temp. I am assuming this is bad info from the sending unit? They are reading with in a degree of each other at start up, but when at operating temp the gauge will read lower. Before the EGR delete I had a delta of about 4-7* oil hotter than coolant.
Old Mar 6, 2017 | 11:53 AM
Yama4fitty's Avatar
Yama4fitty
At cold soak they should be equal as you say yours are. You can try to swap the sensors and see what happens. The sensors are identical so there is no problem doing that.
Bigtruc
20
Dec 26, 2013 10:24 AM
jayc3169
Jul 25, 2011 03:26 PM
03_PSD
15
Jan 21, 2010 01:22 PM
yz400f
Dec 1, 2009 02:08 PM
jtharvey
Jan 24, 2007 09:37 AM
