it sounds like its seized on there try soaking it with wd 40 spay til its wet let stand for a few min. spray again then try wobbling it off thats all i can think of
Stuck good huh? I know I'm going to hear it about this but,I usually take a small screwdriver and tap it in between the two. Work slow and alternate sides. Use an old screwdriver, the end sometimes breaks if you stsrt prying too hard.
Thanks guys I got it. the fan/clutch assembly screws on the end of the water pump shaft. LEFT HAND THREADS amazing what happens when you turn it the right direction!!!!
