Fuel tank valve and gauges
OK folks I need your help. I have been beating my head against the wall and I'm about to go into a coma.
I replaced a fuel selector valve and had to replace the electronic connection plug. I canthink for the life of me can't get the gauges to work. It just pegs out. I followed the instructions and wiring diagrams and aids. I can't figure it out please help.
1985 f350 4x4 7.5
Thanks for the help
1985 f350 4x4 7.5
Thanks for the help
Take the yellow white wire, and with the key in run, engine off, ground the yellow/white and then take it off ground. Each time you do this the gas guage should swing full scale full to empty. It's a little slow so give it some time to make it.
If the above test works, you know the wire to the valve and the gauge up front are all working.
If you want to test the fuel sending units, take the yellow/white and temporarily tie it to the darkblue/yellow, that will be for the front tank. If that works, you can then tie it temporarily to the yellow/lightblue, that will put it on the rear tank.
The pdf for the Pollak 6 port valve is available here: Light Truck 6-Port Motor Driven Valve On Pollak
This is the same as all the reboxed Wells, Store Brand, whatever, 6 port switching valves.
Yellow w/blue stripe = Yellow/lightblue = rear tank sender
Yellow = Yellow/white = wire going to gauge up front
Dark blue = Darkblue/yellow = wire going to front sending unit
Brown = Brown/white = wire going to motor in valve
Orange. is correct. = wire going to motor in valve
Fummins
25
12-28-2016 09:24 AM
NeverFinished
08-06-2013 11:10 PM
Aune163rd
13
10-12-2012 08:25 PM
srqdiesel chef
10-05-2011 09:54 PM
weldingfreak
05-28-2004 04:10 PM
