Dreaded Fuel Selector Valve. (greywynd plz read lol)
Ok guys anybody tell me how this thing works electrically, mine broke when i pulled the motor out of the 90....i just bypassed it but now my gauge does work XD! Can you tell me how I can get the gauge working without the FSV. Greywynd you probably have the wiring diagram for it.
the basic operation of the selector valve is that 2 control wires switch it from one tank to the other, and while moving the fuel valve, also moves a switch for which sending unit is being sent to the gage. therefore, a leaking or damaged valve that has been bypassed could still be used with stock wiring to control the gage.
for bypassing it, i would suspect that maybe you pulled the gage wire from the wrong tank, and are reading the empty tank
selector valve problem?
I have a 92 f250 7.3 idi with some turbo kit on it when I bought it. On my way to work I flipped my selector switch to the rear tank and the truck instantly died and the fuel guage reads full on both tanks. I think it has to be the selector valve it fires up for a few seconds and dies right out starving for fuel. It also had another problem when i bought it and first flipped that selector switch it wouldnt start unless it had over a half tank in the tank you wanted to start on, which leads to thinking it has to be the selector valve. It cranks for about 10 seconds on either tank below half then fires up on both tanks at the same level. If the selector valve is screwed up couldnt it mess with the reading? All the problems point there. Anyone else had anything like this happen?
Fummins
25
12-28-2016 09:24 AM
Jeremy Garrette
12-01-2016 04:25 AM
racine
04-29-2013 05:05 PM
Sierra2500pk
01-04-2013 03:15 PM
weldingfreak
05-28-2004 04:10 PM
