2017 6.7l engine differences
Old Mar 7, 2017 | 08:57 AM
Super~Duty's Avatar
Super~Duty
Hey thanks for all the input everyone! And yes the search function is terrible on here.
Old Mar 7, 2017 | 09:30 AM
Top_Speed1's Avatar
Top_Speed1
As with "most" Forums.
Old Mar 7, 2017 | 09:44 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Originally Posted by troverman
Yeah, Kubota...thanks for reposting. I started both those threads and I'm still questioning what is really "new." Yes, different intake, a few things here and there...but what I'm curious about is the "guts." For example, was the CP4 pump revised any further from the 2015 revision? Is the turbo actually different? Are the injectors actually different? Any changes to the block, pistons, con rods, crank, pushrods, valves, heads, cooling system, etc? That's what I'm really after.
i think we will find out for sure over the next year,
as tuning progresses and people start blowing them up
i have more trouble searching here, the engine doesnt take anything less than 4 letter words
Old Mar 7, 2017 | 06:37 PM
PSM 6.4's Avatar
PSM 6.4
I posted above
The larger turbo, injectors and HPFP were all introduced in the 2015 Gen 2 6.7
There are very small differences between a 2016 and 2017 engine.
2017 turbo has a internal oil drain now (otherwise same specs as 2015-2016 turbos)
Same HPFP as 2016 and below
New turbo pedestal
2017 has different rods to accommodate larger wrist pins
New water pump
New oil cooler
New engine mounts
Old Mar 7, 2017 | 07:40 PM
2009kr's Avatar
2009kr
There is a nice easy search for the forum, just use Google with:
"site:ford-trucks.com" in the search. You can also click "tools" on Google and limit the search time window to the past week, month, etc.
Old Mar 8, 2017 | 01:18 AM
Super~Duty's Avatar
Super~Duty
Thanks! I will try that
Old Mar 8, 2017 | 06:43 AM
Ricohman's Avatar
Ricohman
Originally Posted by PSM 6.4
I posted above
New turbo pedestal
New water pump
New oil cooler
New engine mounts
Any links to the changes of the specs to the rods, wrist pins and pistons? Can't just change wrist pins and not effect all the other components.
The 15 and 16 have different rods, wrist pins and pistons, block ect than the 2014 and older.
I'd like to read some of these specs.
Old Mar 8, 2017 | 09:14 AM
troverman's Avatar
troverman
I posted above
New turbo pedestal
New water pump
New oil cooler
New engine mounts
Where are you getting your info from? From reading PowerstrokeHub, they state the turbo on the 2011-2014 was the SST type (verified) and then in 2015 changed to the larger wheel VGT, (verified) and then changed again in 2017 back to a SST. Here's the quote:
The 6.7L Power Stroke initially employed a unique single sequential turbocharger (SST) which features a dual compressor and single turbine setup affixed to a common shaft. The unit was replaced by a single Garrett GT37 variable geometry turbocharger (VGT) for the 2015 model year, subsequently increasing horsepower and torque in combination with additional upgrades. The SST returned to the Power Stroke for the completely revised 2017 model year Super Duty; torque reached an all time high at 925 lb-ft.
Here's the link: 6.7L Power Stroke Diesel Specs & Info
So maybe they are wrong, but it seems I've heard other info that states the turbo is different as well. When you state "new water pump," I ask "which one?" There are two. When you say the oil cooler is new, I say maybe. From laying under both my 2016 and 2017, the oil coolers appear to be utterly identical. Now, the transmission cooler is new and different. Perhaps that is what you are referring to.
Old Mar 8, 2017 | 09:26 AM
dsladdict's Avatar
dsladdict
What we need is a revision to the 6.7L Coffee Table book that documents the changes for MY2017. Short of that, I'd say it is all conjecture. The only documented change to the oil cooler was the elimination of the "hidden" stud on the back that required the removal of the lower oil pan to access. I also doubt the SST was brought back since Ford was unable to generate enough volume with the SST on the 11-14 MY trucks which resulted in a lack of power at altitude and very little exhaust braking. GM caught onto that and made a series of videos demonstrating all the ways that the turbo was inadequate as well as the "twist ditch" demonstration displaying the open c vs fully boxed frame disadvantages(a little bit of Fords own medicine as I recall Tundra vs F150...)
Old Mar 8, 2017 | 10:19 AM
troverman's Avatar
troverman
I agree - I want the coffee table book! And I'm not defending PowerstrokeHub's assertion that the turbo is new. I recall exactly what you say - less power at high altitude and less exhaust braking. Perhaps they found some way to overcome that. Or perhaps PSM 6.4 is correct that the turbo is basically the same one as the 440/860 engine. The oil cooler stud was removed pretty early on (maybe 2012) as was the plastic oil pan with the quarter-turn oil drain. Oddly, the 2.7L EcoBoost engines in the F-150 have the plastic pan and quarter turn plug, so not sure what was so wrong with that on the Super Duty.
Old Sep 29, 2017 | 09:29 PM
jnuechte's Avatar
jnuechte
Have the 2017 6.7 changes been well documented by now, and if so where?
Tailgate77478
Jun 3, 2015 06:37 AM
blieux1
6.4L Power Stroke Diesel
17
Oct 17, 2013 12:21 PM
Langpie
Nov 22, 2012 09:34 PM
CriticalMass
Apr 10, 2010 12:12 PM
sled_man4ever
4 Cylinder Engines
May 10, 2004 11:36 AM
