Carburetor Finish
Old Apr 22, 2017 | 04:55 PM
  #46
bhalemail's Avatar
bhalemail
I wasn't planning on going but at the last minute i took a day off and went to Carlisle. I bought another holley 847(i have about 8 of them now!) and it had what looked to be original fitting. It was a Ford nut with the compression fitting part of the fitting as the inlet to the carb. It was 1/4" line but the line from the tank to the "flexible line' is definately 5/16" from what i can tell. I'm going to run 5/16" from tank to flex into the pump. From the pump i'm going with 1/4" ford nut to the carb. The truck carb has 4 bolts from top of carb into the bowl and i see no way you could put the the 5/16 flare female fitting in there without hitting that screw. It'll work but i'm honestly not sure if it's correct.
catimann
1947 and Older Ford Trucks
Apr 27, 2019 08:59 PM
Hogtrapper
29
Jan 26, 2015 09:31 AM
CharlieLed
23
Nov 19, 2014 09:59 PM
rcav8or
Sep 13, 2008 09:49 AM
Matt67
Garage & Workshop
Apr 4, 2003 12:25 PM
