no brake lights in '93 e150
Old Aug 30, 2003 | 10:01 AM
tropiclc's Avatar
tropiclc
Bulbs, fuse, and switch all check out fine. Any suggestions?
Old Aug 30, 2003 | 10:14 AM
Duderoy's Avatar
Duderoy
Which switch? Your brakes light generally run though your blinker switch, this is how they are able to share the same wire as the blinkers. I have seen the contacts go bad the the turn switch, plus it lets you know if the rest of the brake circuit is working ahead or behind it. Makes trouble shooting easier. I assume you ment that you checked the activation switch on the pedal.
Old Aug 30, 2003 | 10:28 AM
tropiclc's Avatar
tropiclc
Yes, I meant the brake activation switch. The turn signals work properly. However, the hazards do not work, but they haven't worked for years anyway. Van does have an aftermarket cruise control. Any further input?
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
