Rear End Serial #?
Old Mar 3, 2017 | 08:20 AM
acl9865's Avatar
acl9865
Rear End Serial #?
Can anyone confirm what rear end this is based on serial #?
Looks to me like BB-4193-B (or maybe D)?
Having difficulty uploading pics today but just want to gain some more knowledge on what I've got.
Thanks
Old Mar 3, 2017 | 10:29 AM
harleymsn's Avatar
harleymsn
Thanks
That is not a serial number, it is a part number. Where is that number stamped, a picture would help a lot. Also, are you sure that it is 4193 because I don't see that part number in any rear ends of that era.
Old Mar 3, 2017 | 10:36 AM
acl9865's Avatar
acl9865
Stamped on the rear diff casing. Trying to upload but says incorrect format or file so I'm trying to resolve that.
Old Mar 3, 2017 | 10:42 AM
harleymsn's Avatar
harleymsn
Is there a tag attached to one of the casing bolts?
acl9865's Avatar
acl9865
Old Mar 3, 2017 | 10:44 AM
acl9865's Avatar
acl9865
Old Mar 3, 2017 | 11:37 AM
harleymsn's Avatar
harleymsn
Can you post a picture of the entire rearend, like I said that I can't find that number related to any of the 48-52 rears.
Old Mar 3, 2017 | 11:54 AM
49fordv8f4's Avatar
49fordv8f4
That is the housing part number for the housing half without the pinion, drivers side, Timken/Ford axle F4-F5. The gear ratio is stamped on that housing between the two parallel ribs facing backward. It will have numbers like 6-35 (5.83 ratio) or 6-40 (6.67 ratio) stamped there. There is also a 5.14 ratio, but I don't remember the ring and pinion numbers.
Mark
Old Mar 3, 2017 | 12:22 PM
harleymsn's Avatar
harleymsn
Mark
The 5.14 would be 36-7
Old Mar 3, 2017 | 03:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Mark
That's the casting number for the housing, it's not a part number.
Several hours ago, I looked at every rear axle parts list in the 1948/56 truck catalog, there's no such part number as BB-4193-B
In fact, there no basic part number of 4193 either.
Casting numbers are foundry marks, cannot be cross referenced to Ford part numbers.
Old Mar 3, 2017 | 03:52 PM
46fordtruck's Avatar
46fordtruck
BB is the early big truck truck, starting in '32. That's why you won't find BB parts in the '48 and later books
Old Mar 3, 2017 | 04:48 PM
NumberDummy
1948/56 truck parts catalog.
Parts list #73 = Timken model 53566: 1948/50 F4/F5; F5 Parcel Delivery & COE
Old Mar 3, 2017 | 05:15 PM
49fordv8f4's Avatar
49fordv8f4
The BB number is from '32. The tube should have 7RT-4011-B cast in it close to the spring mount.
Mark
Old Mar 3, 2017 | 05:19 PM
NumberDummy
Mark
BB prefix introduced in 1932, but there are BB part numbers listed in parts catalogs thru at least 1979.
See pic in post #12 for BB rear axle part numbers.
Old Mar 3, 2017 | 06:22 PM
acl9865's Avatar
acl9865
Thanks everyone!
JT250
19
Aug 5, 2013 10:45 AM
Kizer12
Nov 17, 2012 12:09 AM
KRH1326
1983 - 2012 Ranger & B-Series
Mar 3, 2011 03:55 PM
