Hard shift, flashing od light
Old Mar 2, 2017 | 08:57 PM
Blaine Green's Avatar
Blaine Green
Hello everyone, first post here. I have a 97 ford f250 with the 7.3l engine. The od light started flashing, and it started shifting really weird, going up to almost 3k rpm before shifting, wont shift into high gears. I looked online, and everyone said to replace the vss, i did that, the light still flashed and it still shifted hard, so i unplugged the battery and it worked, the light stopped flashing, but it only lasted a few days then the problem reoccurs. so i did the battery thing again, and it worked for about 40 mins, then it started flashing and shifting bad again. My question is, could it be my battery connection? my positive connection wiggles sometimes, if the voltage dropped too much could it effect the brain to throw something out? I'm kind of lost at this point, any help would be so much appreciated.
Old Mar 2, 2017 | 09:14 PM
Kingkong0192's Avatar
Kingkong0192
Highly unlikely but nothing is impossible.
Pull the codes and go from there. All unhooking the batteries is doing is making the computer forget it has a problem. Truck will run fine until whatever is acting up acts up again setting off a code that puts the trans into limp mode.
If the truck has over 100k miles on it and that's the original trans I hate to say it but a rebuild could be needed.
Old Mar 2, 2017 | 10:06 PM
oldbird1965's Avatar
oldbird1965
I agree with King! When it happened to me I was looking at a trans rebuild.
Old Mar 2, 2017 | 10:32 PM
fordman67's Avatar
fordman67
Does your speedo work or abs light on?
Otherwise you need to get the code read by a good shop NOT a parts store reader. That code will tell you which way to go to repair.
And welcome aboard!
Old Mar 3, 2017 | 12:06 AM
Blaine Green
Thanks for the fast replies everyone (: I hope its not a tranny rebuild but i feel it.. And the speedo works and no abs light. I was looking at code readers but I can't afford one right now.. Live out in the middle of nowhere and the town only has like oreilly and autozone stores. They didnt have one for my year truck
aross
21
Aug 19, 2012 06:57 PM
Vinford
Jan 27, 2009 05:03 PM
rachase70
1997 - 2003 F150
13
Aug 31, 2007 09:12 AM
99FordRangerNC
Feb 7, 2005 07:44 AM
MARK7164
Mar 30, 2004 08:02 PM
