3 Starter Relays, Starter Still Won't Disengage -- Sometimes
Folks, on my '88 f-150 4.9L manual tranny, the starter sometimes won't disengage -- maybe once every 30 starts. The engine starts and turns it off as it should. With the starter still cranking and ignition switch off, a light tap on the fender-mounted switch gets the starter to disengage and stop. Or pulling the small wire from the switch gets it to disengage. I'm on my 3rd switch, all different brands -- but none were Motorcraft. Current switch is a Standard Blue Streak. Could I have yet another bad switch?
FWIW, recently replaced starter, alternator (there's a story there!), battery cables. The switch problem didn't change -- it had been happening before those replacements.
Does the key cylinder feel like it catches or sticks when cycling the key from Run to Start and back?
Did you replace both the positive and negative cables?
A Motorcraft fender mounted relay (solenoid) is under $25 on Rockauto. You can probably get one from the dealer in 1 day if you order before 10am, depending on the dealer. Cheap, made in China, or other inferior ignition, cooling, heating parts should be AVOIDED at all cost. Saving a few cents or dollars isn't worth the headache.
All the Motorcraft solenoids on the fender I have seen say to replace with OEM or electrical damage may occur. This was the truth when my boss came to me with 3 starters burning up and the fender mounted relay(solenoid) sticking or the contacts WELDING together.
Hopefully there hasn't been any damage to starter after all the relays have been sticking.
Here it is...
Motorcraft SW1951C is what you need, correct?
When looking for parts, change the years and new updated parts are available and sometimes Motorcraft is listed too.
I agree replacing the starter relay (again) is probably in order, but confirm you can get the relay to disengage by removing the trigger wire. As I previously stated I think you have two problems, but one is triggering the other. If the issue is gone after pulling the trigger wire start there before ruining another relay. I know I can read your first post again, but just confirming 100% that is the case.
Definitely stay away from el cheapo starter solenoids. I've seen this problem happen more frequently with the older style solenoid on vintage Mustangs, but have heard of it happening on our trucks as well. Interesting, when I search for my 94 Rock Auto doesn't list a Motorcraft one. It should be the same SW1951C.
cfassett87
06-25-2012 08:49 AM
blue89
15
02-19-2009 06:27 PM
tysexplorer
16
08-01-2004 11:41 AM
