5th wheel prep package
Old Mar 1, 2017 | 10:01 PM
Mike Mihlfried's Avatar
Mike Mihlfried
If you order the 5th wheel prep package for 370 does that also let you tow a goose neck or or do you also have to order the goose neck prep for 250 Thanks.
Old Mar 1, 2017 | 10:13 PM
Top_Speed1's Avatar
Top_Speed1
Mine came w both preps
Old Mar 1, 2017 | 10:18 PM
workingdan's Avatar
workingdan
It will come prepped with both but you will have to buy the ball and safety chain mounts. I ordered the reese kit from amazon
Old Mar 4, 2017 | 10:04 PM
BowtieConvert's Avatar
BowtieConvert
This system is the bomb! My gooseneck kit is the Ford one. Easy to put in and remove.
Old Mar 4, 2017 | 10:12 PM
Painted Horse's Avatar
Painted Horse
The $370 5th Wheel Prep, are the holes in the bed and all the mounting hardware underneath as well as the plug inside the bed.
The $250 GN is the actual Ball and pucks that the chains hook to.
You will need both part numbers in order to tow a GN trailer
Old Mar 5, 2017 | 10:52 AM
Mike Mihlfried
great Thanks for all the info. I havent looked into the 5th wheel hitches yet. I will be towing both 5th wheel and goose neck. Do the hitches connect to the center hole? Does the safety chain loops interfer with the 5th wheel hitch placement? I am sure this is all figured out i have just never seen it.
Old Mar 5, 2017 | 11:27 AM
System's Avatar
System
Prolocutor
When using a 5ver hitch you only use the outer 4 holes. The center one is GN only. You don't use safety chains when using a 5th hitch. You remove the safety chain eyes when using a 5th hitch as they are in the holes that the 5th hitch uses.
Old Mar 5, 2017 | 12:59 PM
Mike Mihlfried
ok thanks, sounds like a pain? or maybe its easy to remove the safety chain eyes? I would convert my 5th wheel to goose neck but I think I need a slider hitch since I am going to get a short bed pickup.
Old Mar 5, 2017 | 01:55 PM
Painted Horse
The chain plugs are easy to remove, Lift a tab and turn 90° and left out. Takes about 10 seconds each
Old Mar 5, 2017 | 01:56 PM
System's Avatar
System
Prolocutor
No, very easy. The GN eyes come right out just like a 5th hitch would. It would take you all of 10 seconds to remove them. GN conversions on 5vers have been known to cause issues unless you go with a Reese Goosebox. I would keep it as is though. As far as a slider, that's personal preference. I have never run a slider and have always had short beds. You just have to pay attention in tight corners. Some folks like to have it 100% foolproof and want a slider and I understand that. Personally, I just don't want something that big and heavy.
Old Mar 5, 2017 | 02:04 PM
REPO.'s Avatar
REPO.
Agreed. I bought a slider hitch for my truck in 2010. I have never once used the slider option yet.
saucemann
Dec 6, 2022 12:24 PM
ice cream guy
Aug 30, 2020 08:40 PM
slangvel
All Things Towing
Aug 10, 2017 12:54 PM
PrinceValium
Dec 22, 2016 01:41 AM
Segrat
6.7L Power Stroke Diesel
27
Sep 3, 2012 07:57 PM
