Whats my expected hp 360 Fe
I have a 72 F100, i have a 360 I'm throwing a 390 crank rods and pistons in.... Block is decked to absolute 0, bored 30 over ... 9:1 compression,... performance cam edelbrock performer rpm with semi ported gasket matched heads and exhaust.. with holly 4 barrel and headers .... Anyone running a similar setup that can tell me expected hp
the 1.76 sounds correct but I'm having a local race engine place handle the basic rebuild and machining while I handle the porting and gasket matching...unfortunately I don't have the time to do it all myself
... for the street, build for torque.
I definitely know the FE blocks are torque monsters but any idea what the approximate torque curve and max torque will look like? Also any recommendations to get closer to the 350+ hp mark without going to a 429 crank and rods....also ill eventually be running en EFI instead of the 4 barrel and Im still playing with the idea of changing the heads in the future
350 HP? Aluminum heads! Skip the Performer heads and go straight to the Performer RPM and RPM intake. BUT, this is assuming the truck is already equipped with headers and dual exhaust with 2.5-inch mandrel bent tubing.
Btw, there are a couple of FE builds in the Tech Info Compilation...500 HP!
EFI will ensure the engine runs efficiently. The realized gain is depend on how well or bad the existing carburetor is tuned. I'm running Edelbrock's E-Street V1.0 plus a Tremec TKO and have been able to knock down 18 MPG.. out of an FE!
If this is a race engine place seems to me they could give you a better number than us. Once together are they going to Dyno it?
They could if I had the cash to run it lol....eventually I'll put it on a rolling dyno.... On the FE performance thread they were saying just with new intake, carb and headers and increased compression I should be at 400 hp on a stock car 390, .... Im having a 390 crank and pistons swapped in mine and decked and that's still not counting having my heads gasket matched, the performance cam and being bored out ....or the new edelbrock rpm heads I'll eventually be running... Are y'all still thinking only 300 hp? ... And I'm still curious about torque numbers if anyone might know
Torque in 450+ zone.
Your original post didn't mention heads other than gasket matching.
Your cam will determine a lot in the power curve department, as well as peak HP. If you can safely run it to 6500 RPM you will make bigger HP numbers.
Being that it's a 390, it's not going to be helpless at lower revs, but a lumpy cam could make your power curves quite steep, vs. a flat curve which works better with heavier loads and general driving.
Of course, that's part of the fun of a performance build. Feather it around, short shift it, maybe it seems like a pooch. Then you go down a gear and at 3500 RPM the tires go up in flames and the steering seems light.
Serving suggestion.
Serving suggestion.
Serving suggestion.
Serving suggestion.
It's a lengthy read, but well worth the effort. It's not zinc that's the problem with modern oils:
https://540ratblog.wordpress.com/201...-test-ranking/
EstesTruck
16
10-29-2014 10:37 PM
No More Raptor
36
10-21-2013 06:42 PM
jonezzzman
07-31-2013 10:22 AM
skater2570270
13
10-21-2004 10:12 PM
bigern6697
20
12-04-2003 07:48 PM
