Sponsored by: Real Truck
Black stone labs
Old Mar 1, 2017 | 07:55 AM
DeeDubz's Avatar
DeeDubz
Black stone labs
Hey guys, I sent in an oil sample a few weeks ago. How long did it take to get your results?
Old Mar 1, 2017 | 09:47 AM
Mike1's Avatar
Mike1
Blackstone Labs
Old Mar 1, 2017 | 10:14 AM
Justus6.0L's Avatar
Justus6.0L
So what information can you glean from these reports, and should I be doing them?
Old Mar 1, 2017 | 11:52 AM
82_F100_300Six's Avatar
82_F100_300Six
They check for different metals and antifreeze and stuff. There is something called TBN that I'm not sure what it is or indicates. They post a lot of those reports on cumminsforum if you want to see some.
Old Mar 1, 2017 | 12:17 PM
Justus6.0L's Avatar
Justus6.0L
Is this something I should be doing? And if so, what frequency should I be doing it?
Old Mar 1, 2017 | 02:12 PM
dpilot83's Avatar
dpilot83
Oil samples are something that can be used to catch problems before they turn into really expensive problems.
Oil samples can find if you have a leaking intake gasket allowing coolant into your oil. They can find fuel. They can find excessive metals and depending on the type of metal they can give you an idea if it's coming from bearings or rings or what. They can tell you if you're changing your oil too often or not often enough. They can tell you if you have a leak in your air filtration system.
Oil samples are most effective if you have an established history with your vehicle. If you have a crazy reading sometimes it can just be an anomaly so it's a lot better if you have a trend and don't make any rash decisions unless you've got two samples in a row showing a problem.
To have a trend established and be able to depend upon oil samples you should probably sample every time you change the oil.
Old Mar 1, 2017 | 02:16 PM
Justus6.0L's Avatar
Justus6.0L
Got it, good info, thanks.
Old Mar 1, 2017 | 02:25 PM
fordf2501's Avatar
fordf2501
the army sends oil samples with every truck and we rarely changed engine oil we changed the oil filters alot and would top off oil but unless the sample came back stating that the oil needed to be changed it wouldnt happen.
if the master sergeant got the report that metals were found and high volume of metals he would dead line the truck and order a new engine for it
Old Mar 1, 2017 | 02:27 PM
Justus6.0L's Avatar
Justus6.0L
Yeah, but normal people can't afford to just order new engines.
Old Mar 1, 2017 | 03:27 PM
Tom's Avatar
Tom
Here's my last one as an example.
Old Mar 2, 2017 | 07:44 AM
DeeDubz's Avatar
DeeDubz
just received a phone call from them. They just got my sample. Looking forward to seeing whats going on with my truck.
Old Mar 2, 2017 | 04:30 PM
82_F100_300Six
Thanks Tom
(You need to cut down on the cold weather short hops to 7-11 for the slurpee and scratch offs )
Chevmn56
Oct 25, 2017 03:50 PM
pkenn7
Mar 20, 2011 11:35 AM
green53
Nov 20, 2009 04:11 PM
CRJ900
Apr 14, 2004 03:44 AM
