white stuff in oil
Old Apr 13, 2004 | 05:42 PM
CRJ900's Avatar
CRJ900
white stuff in oil
Hey, I changed my oil in my 360fe about a month ago, and when I looked at it today tehre was some underneath the truck, its a white milky substance. When I check the dipstick its also in there. Im using castrol 20w 50. The truck has pretty much sat the whole month but it was started every other day or so. Thanks..
Old Apr 13, 2004 | 05:49 PM
BB's Avatar
BB
Either don't start it every other day or warm it up to burn that crap out of there, it's condensation.
Old Apr 13, 2004 | 06:12 PM
CRJ900's Avatar
CRJ900
ok thanks, do you think its easier to leak when its like this?
Old Apr 13, 2004 | 06:59 PM
BB's Avatar
BB
Yeah, you'll find leaks you didn't know you had when it sits for a while.
Old Apr 14, 2004 | 03:44 AM
scroob's Avatar
scroob
Starting an engine without warming it up, especially in your humid environment, is just not wise. Moisture condenses inside the valve covers, but is never evaporated, and then drips down into the crankcase, where it mixes with the oil and makes the white milky substance.
There is no need whatsoever to start an engine every other day if you're not going to drive it.
