To my surprise the Ford system does this on my XLT without even setting the controls, when I get in after remote starting the heat is blasting and the rear defrost is on, after I turn the key on it reverts to the settings I had left it on and I do have the manual climate controls. It also keeps the headlamps off as I leave them on auto. There is also a reg/green led on the key to tell you the status of a start. I have owned many different systems over the years and this one is very well thought out
Did this system come on the truck from the factory or did you add it ?
would you happen to have any part #'s ? Where did you get the key ?
Found this on the auction site for $169. It's not OEM. The guy directed me to this video. It show it being installed in a 150 but it is the same for the 250 according to him. Not sure I like the idea of tapping lock 3 times but other than that it looks pretty good.
The ford remote access lets you start stop lock or unlock from any where in the world if need be because it uses cell service which is $49 dollars a year
I special ordered the truck so it came from the factory but I would think the add on Ford kit would have the same function's
So do you have a remote start button on your key , or do you have the separate two way remote start fob?
anyway you could post a picture of your remote ?
Thanks !!
No I have the key fob that came with my truck it hasn't changed, the remote access that ford sells over the parts counter works with a phone app. When you use the app by pressing the start icon after a few seconds you will hear your truck crank and start over your phone speaker to let you know it started. It works over the cell towers so you don't need to worry about distance. Maybe I am confused about this post I was talking about remote access not remote start I know nothing about adding remote start, it came on my platinum I added remote access. Sorry if I confused anyone.
