2016 Fuel Filter
Old Feb 28, 2017 | 06:10 PM
O43x's Avatar
O43x
2016 Fuel Filter
Is the 2016 fuel filter different from earlier models? I'm in the process of doing a filter change and noticed the top (engine bay) filter is completely different from what I purchased on Amazon, I know...shouldn't have trusted Amazon. I even asked if the one I bought would fit a 2016.
I installed the bottom filter with no problems, but the top filter is completely different. Now I'm questioning whether or not the bottom filter element is the same.
The part # I purchased was FD-4615. Is this the correct part #?
BTW, my truck is a 2016 F350 FWD.
Old Feb 28, 2017 | 06:32 PM
Dakster's Avatar
Dakster
That is the part # for my 2015... What's different about it? I don't have a '16 to go out and look at...
Old Feb 28, 2017 | 06:39 PM
O43x's Avatar
O43x
On the top filter, the housing is different, it doesn't slide in and lock with a 1/4 turn, it has a 10 mm bolt that holds it down instead. the housing on my truck has a flange to bolt down.
Old Feb 28, 2017 | 06:55 PM
Dakster's Avatar
Dakster
That's what my 2015 has/is like... A bolt near the bottom of the filter that holds it in place. Sounds like you got an older one. My 2011 was a turn a lock with a small screw that was located near the top of the filter.
Old Feb 28, 2017 | 06:58 PM
Just Strokin's Avatar
Just Strokin
Check page 55 of you 2016 Ford Diesel Supplemental manual. The filter part number is the same as you ordered off Amazon - FD-4615.
Also, read your manual on how to change the filters. Starting page 19 for frame filter and page 20 for under the hood filter.
Old Feb 28, 2017 | 07:13 PM
O43x's Avatar
O43x
the part # in the supplemental manual shows FD-4615, and explains how to change the top filter by using the "turning method", that won't work on my truck as the top filter housing is completely different. It bolts down using a small bolt, maybe a 10mm. I'm a bit confused right now.
I do appreciate the help though.
Old Mar 1, 2017 | 05:05 AM
senix's Avatar
senix
you got an old filter. When the 6.7 first came out in 2011 they used that bolt.
In 2012 that was eliminated as not needed. Just do a bolt delete and use the filter.
mrjc
6.7L Power Stroke Diesel
31
May 15, 2021 03:16 PM
coppertales
Nov 13, 2015 04:00 PM
burlhall
22
Apr 27, 2013 02:15 PM
Spirit615
Aug 11, 2005 07:38 PM
