I am having a curious issue in that whatever I plug the engine block heater into via extension co0rd, it trips the GFI or the breaker in the box. No issue with the 350. I guess I have a short in it. Anyone else having this issue? It was working fine...
It's the GFI, replace it and all will be good. They wear out with use, and are especially sensitive in an outdoor / garage environment. I'm in the block heater business.
I've been having the same problem and about to take it to the dealer. It was working fine for 2 weeks until last week (truck is 2 months old)
Tried 3 different cords, went and bought a 12 gauge 25' cord, still blowing different breakers at house, cleaned plug with electronics cleaner and brush.
Took it to work, blew up 2 different breakers at work.
Just had this happen last night. Been about -25C for the past few nights and the truck starts fine, just thought I would plug it in. All my good extention cords are at camp, the one I had left was an old one and about 20 feet long. Will have to try a different cord and different plug in to see if one or the other is the problem.
If it is a 15 AMP circuit and you have other plugs drawing off that circuit, 10 AMPS could be enough to overload it. Try plugging a hair dryer (typically 15 AMP draw) into the same plug and see if it trips the breaker as well.
Take a look underneath your truck. Trace the wiring for the heater plug back into the frame. There is an amphenol(connector) that most likely has water in it. Pull it apart, dry it out real good, and use some dielectric grease around the seal and put is back together.
^^^ This. GFCI have their place but it's going to cause more trouble than their worth with block heaters. Just use a standard outlet and call it a day.
The heater draws roughly 1000 watts int a 120 volt circuit so about 8 to 9 amps. A 12 gauge extension cord is sufficient up to 100 foot assuming no more that 3% voltage drop....
