Been searching for a new grill for my 06 King Ranch. I can find the Chrome with grey inserts but I can't find the chrome with Arizona beige inserts.
Can someone direct me some where? Are the inserts interchangeable? The only thing wrong with mine is the chrome is peeling off. Maybe I can change out the grey inserts with my beige inserts? Any info would be greatly appreciated.
Not cheap anywhere you look, 3-4 hundred. Not worth it to me. I'd get the chrome with the black or grey honeycomb and call it done.
Personally I like the monochromatic. (painted body color)
Im tempted to give it a try (monochromatic). I should be able to get the color in a spray? Any advise going that route?
Any good automotive paint supply shop should be able to put it in a spray can for you, but I'd recommend to have it sprayed by a professional. Here's a pic for ideas.
I'd get a quart and do it myself but I have experience painting. You might want to consider calling around to local shops and get a quote. They sell color match spray bombs but results will vary and with the abuse the grill takes from bugs and stones you want a quality job.
Mine came this way and have no intention of going chrome. True Blue through & through.
Sorry to disappoint but nothing was chrome on my truck except the wheel center caps (still chrome).
I'd start with the most affordable plain plastic grill and go from there. I wish I had an answer for de-chroming plastic but I don't.
No worries. The black ones run less than 60.00. Would rather buy one than have to do all that sanding and prep
