86 inline 6 doesn't start
Old Feb 28, 2017 | 07:18 AM
Toddster's Avatar
Toddster
So this weekend my truck was running great I had just replaced the turn signal switch and then it wouldn't shut off and the lock cylinder would turn without the key in it. So I replaced the ignition switch and the lock cylinder. I had my buddy trying to start it and it would turn over but not fire. I saw the, what I assume is the hot wire on the coil, the green wire smoking. The wiring looked really deteriorated so I went to a junkyard and found some good wiring from an 85 and replaced all the wiring and the coil. The battery died so I haven't tried to start it but is there anything else I should look at. There was a lot of exposed wiring and that green wire was exposed too so that was why I replaced all of it. Any help or thoughts would be greatly appreciated.
Old Feb 28, 2017 | 08:20 AM
Franklin2's Avatar
Franklin2
Try to crank it over and see what you have.
Old Feb 28, 2017 | 08:56 AM
Toddster's Avatar
Toddster
cool. When I get off work I'll try and let you guys know what happens
Old Feb 28, 2017 | 12:51 PM
1986F150six's Avatar
1986F150six
Usually, when something stops working just after a repair has been made, that something was caused by the "repair". Are you certain the ignition switch [electrical at the bottom of the steering column] is properly adjusted?
Old Feb 28, 2017 | 01:24 PM
Toddster's Avatar
Toddster
Well I'm going to replace it and check the adjustment
Old Feb 28, 2017 | 08:08 PM
Toddster's Avatar
Toddster
Well you guys were right. I replaced the ignition switch and adjusted it and it fired right up. Thanks again!
roddin41
Jul 3, 2012 02:06 PM
XXL Supreme
Jun 7, 2010 05:17 PM
Seifferlein
31
Mar 30, 2004 08:23 PM
tamarackstyle
Mar 26, 2004 11:37 AM
CowboyMjoh
Electrical Systems/Wiring
Nov 9, 2001 03:28 AM
