7.3 running rough
Old Feb 27, 2017 | 05:49 PM
jwoo99's Avatar
jwoo99
7.3 running rough
Hey all, new to diesels but enjoying it so far. Just got a 2000 excursion 7.3. The history on this veh is a little cloudy. The body has 300k on it but I was told the engine was swapped with 150k on new engine. I have been doing a lot of catch up using youtube with DieselTechRon (tragic!) and other vids, so I am aware of most of the basic known issues with these 7.3's. I just wanted to throw this out there before I dig in. The motor really stumbles at low RPM. When driving , if I put my foot into it, the engine smooths out. When driving at lower speeds (like a residential area) shifting from 2nd to 3rd the RPMs drop and the engine vibrates. Again if i get on the throttle the engine runs better. ICP had oil on connector. Have not checked IPR. I performed the buzz test with Car gauge pro using BAFX OBDii. I have seen the issue with the VC gasket connector. But I keep reading about issues with the IDM. I see buzz test shows the p1293 bank 1 (VC harness?) but also noticed no code for cyl #4. During buzz test, only two injectors sounded muted (#2 & #8) all the other injectors sounded normal (normal to me). Fuel gauge on dash always reads full so i guess that's the fuel sender and the so the tank comes down and maybe the mod. My plan is to perform a fuel pressure test. Bank 1 VC harness, then check IDM connections. Looking for advice or history to make sure I'm not missing something. Thanks!!
Old Feb 27, 2017 | 09:34 PM
agsmv1's Avatar
agsmv1
Test procedure for the harness in Post #5
https://www.ford-trucks.com/forums/8...-inj-code.html
Old Feb 28, 2017 | 01:11 AM
Stewart_H's Avatar
Stewart_H
Moved to the 7.3L PSD forum.
Stewart
Old Mar 1, 2017 | 08:45 AM
JIMRSX's Avatar
JIMRSX
My E99 with 76k miles is doing similar as your truck. ICP connection on mine is clean though. ICP numbers via my scan guage look good too. Have a blue CPS in it (ran much worse with grey CPS). I have ordered an AE with Ford bundle from Riff-Raff that I am expecting by the weekend. I will do the scans with that and keep you posted in hopes that maybe I find something that will help you out too.
chasteen1156
35
Nov 5, 2025 09:37 PM
TSBAHRS
13
Jul 19, 2019 12:48 PM
Sondre Næss
Apr 1, 2017 04:01 PM
fullsize4wd
Apr 5, 2014 02:18 PM
commandersander
Sep 18, 2012 07:05 AM
