Ok, but do you have any part numbers for the shocks. BDS doesn't make a 6" lift for 2017's yet. And from what i found, 2016 is different from 2017 sizes. Also fox shocks haven't made a shock for 6" lifted 2017's yet with the proper valving, from what i can find. So the question i guess is, are those rear shocks from a 2016 f350 with a 8" lift? Cause those seem like the proper measurements for a 2017 with a 6" lift. I'm having a hard time finding the proper answer and just thought maybe the guys that have a 6" lift would know.
hm I have two lifted trucks with fox shocks one to ten , kelderman 4 corner air . and one 6 inch fts lift .that rides absoulutely awsom .. dual remote reservoir shocks .. must be mistaking on fox shocks as my 17s are sweet riding ..
Wondering what everyone is doing about the speedo and TPMS?
TPMS you can do with Forscan, speedo you can do with the hypertech speedo calibrator. It's a middle man device that intercepts the reading from the sensors and adjusts before it hits the ecu. You have to remove your dash to install, but it's dead simple to do.
