Need help
Old Feb 25, 2017 | 07:08 PM
Jsmith5.0's Avatar
Jsmith5.0
Need help
Im new to diesel's we have a 03 6.0 the truck has been sitting for 2 year it ran fine but the turbo came in slow so we had it cleaned then it ran fine for the test drive then after that no power put a new map sensor on it they welded the egr that was the same no power put a new egr valve on it no power. After the truck warms up it runs great.
Old Feb 26, 2017 | 08:02 PM
BLADE35's Avatar
BLADE35
Welcome bro
These guys will get you going
Going to need a gauge to check the FICM voltage
Also make sure it's not making oil
Better make sure you battery are good sitting that long too
Alternator output would be,worth looking at maybe clean battery cables
Old Feb 26, 2017 | 08:10 PM
bismic's Avatar
bismic
You need gauge system to read all of the important PIDs. Low power and low boost can come from quite a few different causes.
Also I assume that there are no leaks in the charge air system?
Things to check:
- FICM voltage and batteries as Benny said above!
- VGT operation
- High Pressure oil (ICP psig and volts, IPR% duty cycle, ICP desired).
Maybe even see how it runs with the ICP unplugged.
Old Feb 26, 2017 | 08:11 PM
Jsmith5.0's Avatar
Jsmith5.0
Originally Posted by BLADE35
Welcome bro
new batterys i had a guy look at it and he said everything was ok but like i said it only does it when its cold after it warms up its fine
Old Feb 26, 2017 | 08:21 PM
BLADE35's Avatar
BLADE35
What all did he check
Old Feb 26, 2017 | 08:29 PM
Jsmith5.0's Avatar
Jsmith5.0
Not sure i have edge 15002 coming should be here in a few days. I will ask him tomorrow and repost and let you guys know
Old Feb 26, 2017 | 08:48 PM
Lubbockguy1979's Avatar
Lubbockguy1979
The edge wont tell you much. If you use a android phone you can gey a obd2 bluetooth adapter and buy torque out of the android store for like 5 bucks. Pretty easy way to use a android device as a gauge setup. Need to look at ficm voltage, icp just off the top of my head
Old Feb 26, 2017 | 09:02 PM
robs97z28's Avatar
robs97z28
SG II
I have been using this for years.
Linear-Logic ScanGaugeII with trip data computer, real-time display of operating conditions and scan tool SG2 - Read 4 Reviews on Linear-Logic #SG2
Old Feb 26, 2017 | 09:09 PM
Lubbockguy1979
Have you tried torque?
Old Feb 26, 2017 | 09:11 PM
Lubbockguy1979
Just stuff i threw together to show what can be done. I use a tablet to monitor when i need to. Used a edge evo 99% of the rest ofnthe time
Old Feb 26, 2017 | 09:12 PM
robs97z28's Avatar
robs97z28
No, I have no need to. this thing is always there and turns on automatically when I start the ex. It has saved my butt many times.
Old Feb 26, 2017 | 09:15 PM
Lubbockguy1979
It is alot more expensive and less capible is why i was asking. Its been a staple of 6.0 guys though for a while so i understand. In my old truck i ran a bunch of analog gauges and have since tried to get away from that and more to something cost effective that can easily move to any vehicle i drive.
Newgutters
Jan 29, 2018 08:51 AM
tr0y
Apr 8, 2015 09:47 AM
Skiddy 1
May 9, 2014 10:02 PM
RideDiesel88
Dec 5, 2012 08:48 PM
bablake
Jan 12, 2009 12:16 PM
