Oil Change Required
Old Feb 24, 2017 | 11:46 AM
EpicCowlick's Avatar
EpicCowlick
Oil Change Required
So I get this notice this morning. No biggie, just need to change my oil. But look at the odometer. 4,000 miles? That's pretty early isn't it? Delivery was 10/31 last year. I was planning to change at 5,000 but I guess I'll do it tomorrow. Because I do as I'm told.
Old Feb 24, 2017 | 11:50 AM
JT_Guitar's Avatar
JT_Guitar
A new engine wears in... I'm going to do my first at 1000 just because I assume the wear process is most prevalent when new.
Old Feb 24, 2017 | 12:27 PM
ravill's Avatar
ravill
Wow, that is much sooner than I would've thought.
There has to be guys around here with more miles than that without an oil change recommendation.
Old Feb 24, 2017 | 12:31 PM
oklarado's Avatar
oklarado
Some have claimed the factory fill has additives and not to change it early.
Old Feb 24, 2017 | 12:42 PM
crewzer's Avatar
crewzer
Exclamation
The oil minder will advise a diesel engine oil change at 3K-5K miles for "extreme" use conditions:
  • Maximum load or towing
  • Extreme hot or cold operation
  • Use of high sulfur diesel fuel
HTH,
Jim / crewzer
Old Feb 24, 2017 | 12:46 PM
EpicCowlick
I guess this is the difference in "Intelligent" oil minder. My 2011 was more of a mileage-based reminder than anything else. It never came up earlier than 7,500 miles on its own. I actually have no problem with changing at 4,000 if it's necessary and it's a good case study to see that it actually works as advertised. Oil change video tomorrow. I'm looking forward to isntalling the Fumoto valve knock-off on my bench.
Old Feb 24, 2017 | 01:01 PM
RubyRed350Platinum's Avatar
RubyRed350Platinum
Mine showed at 4300 but I idle a LOT.
Old Feb 24, 2017 | 01:06 PM
System's Avatar
System
Prolocutor
I'm changing at 1k too. Let the filter collect any SWARF for a thousand. At that point I want to switch to 5W40 synthetic before I start to tow heavy anyway.
Epic, I'm glad you posted this. This time around, when I change at 1k, I will reset my oil life minder so I know it's accurate. I never did in the past and just changed at 5k intervals and reset it on the fly whenever it popped up as I knew I was ahead of the game.
Old Feb 24, 2017 | 01:25 PM
JT_Guitar's Avatar
JT_Guitar
Any substantiation of this? You'd think they'd put it in the manual. I put 250,000 on my 00' 7.3 with nary an issue after doing the 1000 mile change. Hmmm.
Same here...
grampscamper's Avatar
grampscamper
On my 2013 I did an oil change every 10,000 kilometres, roughly 6,000 miles. Reset it every time. Once I went a little over and I got the message to change the oil. I tow our 5th wheel 75% of the time.
I'm planning a big trip a few weeks after I get my truck. I'll make sure I change the oil before I leave.
Thanks for posting.
Old Feb 24, 2017 | 01:30 PM
oklarado's Avatar
oklarado
Same here...
Hey I read it on this forum, it must be true.......
Old Feb 24, 2017 | 01:32 PM
JT_Guitar's Avatar
JT_Guitar
LOL... Quote of the day!
Old Feb 24, 2017 | 01:35 PM
PwerStroke99's Avatar
PwerStroke99
im pushing 6800 miles and still no message to change oil. But I am going to change it at 7500, that's when I will need to add DEF. Just ordered two oil filters from dieselfiltersonline.com
Old Feb 24, 2017 | 01:38 PM
Uzumati's Avatar
Uzumati
Mine hit last week at 5900 probably do the next one a little early for the 10k service
Old Feb 24, 2017 | 01:42 PM
oklarado's Avatar
oklarado
Do you know if they still use that round style water separator filter like the 2016's? I watched a youtube video of a filter change and the housing was different than what I've seen people post on here. The new housing appeared to be rectangle on the bottom.
