Is it just me...
Old Feb 24, 2017 | 09:49 AM
'89F2urd's Avatar
'89F2urd
Power helps the e4 feel less doggish, huge difference in the way mine feels after build than before, no change in Trans.
Old Feb 24, 2017 | 10:08 AM
GoinBoarding's Avatar
GoinBoarding
There have been times, 3rd gear with a load (especially if its combined with a classic WY headwind), a big hill slowly gets steeper, I slowly tip into the throttle to maintain speed, and eventually I'm compressing the floor mat with the throttle, and it won't shift. It will shift if it remains WOT long enough, especially if speed drops. Thats pretty rare though, normally I kind of twitch my foot to quickly increase throttle position maybe 20% and it drops one gear reliably. If I want to go fast the E4OD isn't holding the truck back, but perhaps 96' programming is a little more refined? Punching it at 70 it'll get to 90 in a hurry, passing is no problem.
Edit: my engine is not stock. That does seem to make a big difference.
Old Feb 24, 2017 | 11:10 AM
ng19delta's Avatar
ng19delta
I'll be stopping by Harbor Freight for a fuel injection pump pressure tester set up on the way home...
Scott
Old Feb 24, 2017 | 12:07 PM
Nothing Special's Avatar
Nothing Special
The E4OD in the '95 F-150 I had (351, 3.55 gears, 33" tires) worked just like I wanted. It would downshift quickly if I floored it, but would stay in OD as the throttle slowly went to the floor. In fact it wouldn't downshift when I was using speed control, even losing speed with the throttle wide open rather than downshifting. I know a lot of people wouldn't like that, but I much preferred it over having the trans hunt between gears (if I was losing speed I knew I needed to take it out of OD).
The E4OD in my '97 F-250HD (460, 4.10 gears, 32" tires) is very different. It downshifts much sooner than I want, no matter how slowly I add throttle. I can't use speed control on it with a load in any hills (unless I don't use OD). The 460 with lower gears should be able to lug a lot better than the 351 with taller gears, but this trans won't let it.
Either one downshifted quickly if I abruptly floored it, and gave good performance when I asked for it.
Personally I don't like autos, but even with my complaints about my '97 it's the second-best auto I've driven (the '95 being the best). So I'm still a fan of the E4OD (at least as far as autos go).
Old Feb 24, 2017 | 06:22 PM
ng19delta's Avatar
ng19delta
Fuel Pressure indicated on the new gauge is 30PSI, either tank...(both are the original pumps) Should be 40PSI I understand...
Scott
Old Feb 24, 2017 | 06:33 PM
rla2005's Avatar
rla2005
Scott
30-35 PSI at idle is good. Pull the vacuum line off, it should go to 40-45 PSI.
With the vacuum hose on the pressure should increase with throttle. Best test is under load. Pressure should never drop below idle pressure.
Old Feb 26, 2017 | 07:18 AM
Motorhead351's Avatar
Motorhead351
Or does the E4OD suck?....You stepped into THAT, and she TOOK OFF SCREAMING... I see the newer pickups doing just that-
Even the new and newer, automatic trucks, not limited to fords offerings, can perform the way youve described and hate.
Its kind of an auto thing to a certain extent but youve been given good advice to troubleshoot, just in case. Good luck
Right or wrong, ive yet to like a factory auto transmission, even modified/tuned. The problem isnt off idle acceleration, its having a transmission that responds in a way thats pleasing, during the many other driving conditions.
Old Feb 26, 2017 | 07:24 PM
pat67shorty's Avatar
pat67shorty
Most of the problem is the factory shift strategy. It is programmed for economy IE lug the engine as much as possible. It also locks the torque converter at WOT in 2nd and 3rd gear... So you loose the torque multiplication of an unlocked converter.
95WorkHorse
Nov 17, 2017 06:43 AM
Blankie
Jan 17, 2008 06:57 PM
ford351c
Jun 7, 2005 09:20 PM
Montana Bronco
1978 - 1996 Big Bronco
Dec 2, 2003 12:46 AM
handymansc
Nov 11, 2003 11:15 PM
