Emissions information.
Old Feb 23, 2017 | 06:52 PM
Chris Crews's Avatar
Chris Crews
I was at work today and talking with a guy who has a friend who runs a diesel mechanic shop. Log sorry short he said that you can remove the dpf system like it clamps off and can be replaced with a pipe and the egr can be removed - basically all emissions stuff can be removed. He said doing this will help prolong the life of the truck.
I told him.,,, wouldn't that void the warranty? He said the only time it would void it is if the truck had something mess up on it and I didn't put the emissions stuff back on when I take it to the dealership.
Is is this true and can this work?
also if it does work.... how long is a safe time to begin removing emissions stuff?
thanks
Old Feb 23, 2017 | 07:15 PM
troverman's Avatar
troverman
Removing the emissions controls on a modern diesel is not uncommon. It involves removing the DPF and disconnecting the DEF injector and potentially bypassing the EGR system. It requires using a tuner program to tell the engine computer not to attempt to regenerate or inject DEF. This whole process is called "deleting."
Overall, deleting will improve fuel economy and possibly increase power. The only thing "harmful" about modern emissions controls is the active regeneration process and large amounts of EGR. It might be helpful to prolong life, but I doubt the difference would be drastic.
Its also a violation of Federal law, and states that require emissions inspections will obviously create a problem if you are deleted...you won't pass.
Warranty for the entire engine can be denied if you are deleted. Some dealers are pretty lenient but others are hard nosed and certainly if a regional rep gets involved, deleting can certainly be a reason for warranty voiding.
Old Feb 23, 2017 | 08:13 PM
Oz97tj's Avatar
Oz97tj
As said above, and even if you reinstall stuff they can still see the computer was tampered with so again depending on dealer. However, it doesnt void warranty on everything. Just engine related stuff and those usually tend to be good for a long time. The ones that have issues usually have issues early on.
Old Feb 23, 2017 | 10:20 PM
BII Plow Truck's Avatar
BII Plow Truck
Nowadays everything is recorded in the ECU, so Ford would know.....it's in there.
Old Feb 24, 2017 | 03:49 AM
Chris Crews
Oh so if I put the stuff back on they can still read it in the computer... hmm. Well also I live in a no emissions state- with that being said would that play in my favor at the dealer and how reliable are these engines?
Like is the 6.7 known for having any issues? If so that would make me want to wait on the delete
Old Feb 24, 2017 | 04:15 AM
kry226's Avatar
kry226
The 6.7 has had a couple of hiccups. But more importantly, if you delete, you become your own powertrain warranty station, in addition to the aforementioned federal issues. All of which have financial implications.
Old Feb 24, 2017 | 05:11 AM
Chris Crews
So pretty much the best thing to do in this situation is just ride out the warranty and then delete after. In all your opinions.
Old Feb 24, 2017 | 05:14 AM
kry226's Avatar
kry226
At least. And even then you must assess your risk tolerance.
Old Feb 24, 2017 | 06:31 AM
troverman's Avatar
troverman
I'm not planning on deleting at all. There's really no reason to. The emissions systems have become pretty darn reliable nowadays, this engine has tons of power, and fuel economy is good enough. I'm not concerned about hurting the engine (any harm caused by the emissions system can pretty much be offset by changing the engine oil a little bit more frequently).
Ford certifies this engine to 250,000 miles before any major engine rebuild.
The only scenario I can ever imagine deleting is if the DPF needs to be completely replaced and the cost is exorbitant. In the meantime, by not deleting, you're helping keep the environment cleaner.
Old Feb 24, 2017 | 07:08 AM
Frantz's Avatar
Frantz
It's illegal. Federal law. Has nothing at all to do with your state. Also, the system works just fine, so unless you're doing some major modifications to power (when 925 isn't enough), then the gains aren't worth the risks at all.
Old Feb 24, 2017 | 07:19 AM
johndeerefarmer's Avatar
johndeerefarmer
Every diesel tech that I know will tell you that the emissions equipment is troublesome. Most that have diesels have them deleted. If you go this route you need to be able to put it back to stock as it's illegal for a dealer to sell a deleted truck if you decide to trade it in later
Old Feb 24, 2017 | 07:21 AM
troverman's Avatar
troverman
Frantz, I would say it has a lot to do with your state. I'm not advocating deleting your truck, but while tampering with emissions equipment is a violation of Federal law, the risk of having this discovered by the Feds is certainly less likely than winning the Powerball jackpot.
In my state where HD pickups are exempt from emissions inspection (safety only)...there are simply tons of deleted pickups running around. Plenty of 6.7L Fords.
Old Feb 24, 2017 | 07:25 AM
Oz97tj's Avatar
Oz97tj
I dont know about that. Ive recently looked at two deleted trucks on dealer lots. Maybe depends on the dealer?
To the OP, Im not saying dont do it. Ive done it before. However, as stated the gains arent what they used to be on older diesels. And yes its illegal no matter the state but many dont check and youd never be caught. Another downside is if you tow, even with clean tunes, youll have aome soot on your trailer. A pain if its a camper or something. First thing id do is talk to your service dept to see how they feel and then go from there.
Old Feb 24, 2017 | 07:29 AM
johndeerefarmer
Texas law
https://www.tceq.texas.gov/airqualit...tampering.html
Chris Crews
Jan 27, 2017 07:59 PM
TADcanoe
6.4L Power Stroke Diesel
29
Mar 2, 2015 02:33 PM
captainkbt
20
Jul 29, 2013 04:55 PM
Mud Doc
Nov 22, 2008 01:16 PM
russ_d_t
Sep 30, 2007 03:41 AM
