Mysteriously gone ABS module
Old Dec 14, 2021 | 06:48 PM
SpoolinJay's Avatar
SpoolinJay
Originally Posted by Stroker07
Did you by chance have a screwy fuel gauge?
I have the the same issue and have done everything also with no fix in site.. I even switched pcm out.. I do have a fuel sender code though.. why do you ask?
Old Dec 14, 2021 | 11:21 PM
six_eaux's Avatar
six_eaux
Could be your instrument cluster. My experience started with odd speedo stuff like no reading at all (intermittent) then, even with cruise set at 70, maybe a swing up to 100 or down to 30 with no actual change in speed. Torque Pro or Forscan should help you verify since they will reflect what the PCM is seeing.
fancyketchup
Feb 20, 2015 10:15 AM
george14094
Jan 17, 2013 07:25 PM
afinepoint
May 17, 2010 12:27 PM
dodgefreak8
Sep 20, 2008 11:21 PM
Ryan50hrl
Jun 16, 2004 09:49 AM
