VIN ID
Old Jul 17, 2011 | 10:09 PM
broken knuckles's Avatar
broken knuckles
VIN ID
W# F10DR699590
WB 129
COLOR M
MOD F100
BODY E81
TRANS A
AXLE 08
thanks
Old Jul 18, 2011 | 07:33 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by broken knuckles
F10DR699590 / WB 129 /COLOR M / MODEL F100 / BODY E81 / TRANS A / AXLE 08 / GVW 05000 / Cert. net HP 172 / RPM 4000 / DSO ?
F10 = F100 2WD
D = 352 2V
R = San Jose CA Assembly Plant.
699590 = 1965, assembled June 1965.
129" Wheelbase.
M = Wimbledon White.
F100 2WD, 5,000 lbs. GVWR
E81: E = Red Crush Vinyl & Red Ladder Pattern Woven Plastic / 81 = 81B Custom Cab.
A = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
08: Ford 9" Rear Axle / 3.50-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
DSO code omitted.
Old Jul 18, 2011 | 10:15 AM
BeerKnurd's Avatar
BeerKnurd
VIN ID Help
# F10JR240117
WB 122
COLOR J
MOD F100
TRANS A
AXLE 11
MAX GVWLBS 05000
CERT 114
RPM 3600
DSO - N/A
Thanks
Old Jul 18, 2011 | 10:26 AM
NumberDummy
Originally Posted by BeerKnurd
F10JR240117 / WB 122 / COLOR J / MODEL F100 / TRANS A / AXLE 11 / MAX GVW LBS 05000 / CERT 114 / RPM 3600 / DSO - N/A
Welcome to FTE
F10 = F100 2WD
J = 223 1V I-6.
240117 = 1962, assembled December 1961.
122" Wheelbase.
J = Rangoon Red.
A = Ford 3 Speed Manual Transmission.
11 = Ford 9" Rear Axle / 3.70-1 / non Limited Slip / 3,300 lb. Rear Axle Capacity.
114 net HP @ 3,600 RPM
No DSO code on trucks of this vintage unless a Domestic Special Order.
Old Jul 18, 2011 | 10:30 AM
BeerKnurd's Avatar
BeerKnurd
Thank you!
MartyB
Jul 8, 2010 12:17 AM
MW95F250
Jan 17, 2003 10:33 AM
Vampiro
Jun 2, 2002 07:11 PM
72_ford
Apr 18, 2002 09:12 AM
pickupman
Mar 23, 2001 07:22 PM
