Sponsored by: Real Truck
Transmission issue
Old Feb 21, 2017 | 06:34 PM
00SuperDuty7.3's Avatar
00SuperDuty7.3
Transmission issue
Hello fellow Ford owners and drivers. I drive a 2000 F250 XL Super Cab LB 2WD 7.3 Powerstroke. i drive like a grandpa. No rompin on the accelerator or anything. I was leaving the house got up to about 35mph and the truck lost acceleration. Motor still running fine. I coasted onto a side road. Put it in park, killed it, started it again and same thing. Will not go into drive at all. However will go into reverse just fine and accelerate in reverse. Input would be greatly appreciated!! Desperately wanting my favorite means of transportation back!
Old Feb 21, 2017 | 06:41 PM
seville009's Avatar
seville009
Did you try it in first or second gear (not "drive")?
Old Feb 21, 2017 | 06:46 PM
RV_Tech's Avatar
RV_Tech
How many miles? I think your transmission is history would be my guess. I think something broke inside.
Steve
Old Feb 21, 2017 | 06:57 PM
00SuperDuty7.3
203,000 miles. I tried "drive" and 2nd and 1st
Old Feb 21, 2017 | 07:01 PM
RV_Tech's Avatar
RV_Tech
Given the tranny is the weak link on our 7.3s, I think yours did well.
Steve
Old Feb 21, 2017 | 07:02 PM
00SuperDuty7.3
I had it rebuilt once already in spring of '14. Fair to say it's just time to get a new one?
Old Feb 21, 2017 | 07:21 PM
onebadv2's Avatar
onebadv2
I think I would be paying a visit to whoever rebuilt it in less than 3 years ago, especially if you drive the way you say you do. How many miles on rebuild and was it a complete rebuild or what?
Old Feb 21, 2017 | 07:23 PM
00SuperDuty7.3
Rebuilt at 136,000 and I've already called that guy. He gave me a 1 year warranty and that was it
Old Feb 21, 2017 | 09:13 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's possible the feed bolts under the valve body have loosened, which will leak enough pressure to cause this. Either that or the trans has had an internal failure.
Old Feb 21, 2017 | 09:23 PM
00SuperDuty7.3
just get up in there with a wrench or do they need to be tightened a specific amount?
Old Feb 21, 2017 | 09:32 PM
P.Bronner's Avatar
P.Bronner
Considering its a 4R100, its probably broken or burned up. I traded in my '02 when it was only about 3 years old / 42,000 mi. because I couldn't tow in the mountains without it cooking itself. One problem, in factory form, is the torque converter doesn't lock until you get to 3rd gear. As soon as it drops down to 2nd, like on a steep grade,The T/C unlocks and the fluid temp skyrockets. Aftermarket programming can fix this. Maybe Ford has newer programming as well, I don't know. Our last trip with this truck was punctuated by a long hill that produced a pegged trans. temp gauge and a flashing O/D Off light. I was waiting for the "BANG" followed by a cloud of gray smoke, but we made it over the top. Traded it off the next day. Good truck, good engine, **** poor transmission. The trailer (5th wheel RV) had a wet/loaded road weight of 11,500 lb.
Old Feb 22, 2017 | 10:00 AM
Mark Kovalsky
Every single nut and bolt on the truck has a correct torque value. I don't have a chart to be able to tell you the correct number, but I'm sure someone else has it.
Old Feb 22, 2017 | 10:12 AM
andym's Avatar
andym
To be fair, the "problem" with the 4R100 is lack of adequate cooling. This is why the swap to the much larger 6.0 cooler is such a popular option in 4R100 circles. I have one on my truck and my transmission temps stay well under control, even when towing my RV through the mountains. Keep it cool and it will last a good long time.
Old Feb 22, 2017 | 10:52 AM
plentyoroom's Avatar
plentyoroom
mine didn't die, but would hesitate to shift. it would rev up before going into next gear. took it in to get checked and overdrive clutch was gone, material all over the inside. just a matter of time for the others to follow. had to get rebuilt. replaced cooler, outer filter and all the outer plumbing as well. now i have to take it in again, leaking tranny fluid and is only been 2 months since was done. it is under their warranty still.
Old Feb 22, 2017 | 12:09 PM
DarkStarMedia's Avatar
DarkStarMedia
I have almost 300k miles on my 4r100 in my 97 powerstroke... still works.
It will slam into 2nd or 3rd every so often so I let up on the throttle during shifts but once it's in gear it holds just fine even at full throttle.
I think it might just be tired springs in the valve body.
Richard
