AC stops working once in a while
Old Mar 26, 2017 | 01:56 PM
ugh3012's Avatar
ugh3012
Here is the picture of the clutch. The bearings were destroyed and jammed to one side. The truck could not start because the belt will not turn due to jammed pulley. New clutch on order. I did not want to replace the compressor at this time. It seems to be fine.
Old Mar 26, 2017 | 02:00 PM
banks0531's Avatar
banks0531
I would say its shot. I would install new clutch, check gap and put some blue lock thread on clutch bolt when you have proper gap.
Old Mar 28, 2017 | 10:17 PM
troposcatter's Avatar
troposcatter
The AC in my wife's 2001 f250 was stopping once in awhile but would always work when I looked at it, it finally stopped working completely I checked the freon pressure again and it's good , the switch is closed so it indicates the pressure is good but there's no voltage to the sensor so now I need a schematic to find out why.
MyBoyBlue78
2009 - 2014 F150
May 18, 2014 09:32 PM
Big Norm
1997 - 2003 F150
Sep 16, 2013 09:53 PM
bigtimebubba
May 23, 2009 10:25 PM
Deebo
Aug 16, 2007 09:46 AM
