Can't get old gasket off
Replacing a water pump. Got where it bolts onto the engine block clean but I can't for the life of me get the metal plate that goes between the 2 gaskets clean. I got it smooth to the touch but still black from old gasket.
also my new pump came with 2 sets of gaskets. Paper and rubber. Planned on using the rubber. And thoughts?
thanks
thanks
So your new pump didn't come with a backing plate? Sounds cheap.
Just a thought...
I've used Permatex #1, the non-hardening sealant often, a thin layer. If the previous pump was sealed with P #1, would brake cleaner dissolve it? I've used rubbing alcohol (Isopropyl alcohol), like 70%, to get it off my hands, and anything else. Available at Walmart for $1.xx for a quart of 70%.
Just a thought...
If "smooth" means your fingertip rides up and over it, no, for me that would not be good enough, I wouldn't want to have to take it all apart again 2 weeks later...
Since its a steel plate, have you tried a putty knife in good condition? Or a single-edge razor blade holder with a good blade (like for taking registration stickers off of windshield, etc.)?
Being steel, much less likely to gouge than aluminum!
If you feel that it doesn't really have any "thickness" to it, I'd say you're good to proceed.
command37
13
05-10-2017 01:57 AM
bluemtn95ford
01-20-2014 08:56 AM
Finger__Rachet
12-09-2012 10:00 AM
wdhille
09-09-2009 07:32 PM
Stampede
General Automotive Discussion
05-03-2004 02:06 PM
