Battery interconnect wire
Old Feb 19, 2017 | 09:57 PM
bthr22's Avatar
bthr22
Does anyone have the upgraded wiring with the battery interconnect wire from ficmrepair.com? I just installed my 230A alternator and upgraded wiring kit, but I'm not sure where the additional ground goes for the driver side battery. That's the only part without a picture on the website. It mentions the driver side frame and engine block, but I couldn't figure it out.
Old Feb 19, 2017 | 10:28 PM
TooManyToys.'s Avatar
TooManyToys.
Ed added the cable I promote in my battery cable upgrade video to balance the current flow from each battery. You can jump through just to where it shows the connections.
Old Feb 28, 2017 | 08:38 AM
bthr22's Avatar
bthr22
Thanks, that helps! It's probably easiest to connect from the top with the air filter removed?
Old Feb 28, 2017 | 09:51 AM
TooManyToys.
Depends how nimble you are. I set up mine without the stator, ducting, battery and battery tray.
Old Feb 28, 2017 | 09:58 AM
akblackfoot's Avatar
akblackfoot
https://www.ford-trucks.com/forums/1...upgrade-3.html
Old Feb 28, 2017 | 11:10 AM
Justus6.0L's Avatar
Justus6.0L
Good info, thanks for the video.
hhight
Aug 7, 2014 09:23 PM
BIGRED 7.3L
16
Oct 5, 2011 12:01 PM
handyandy123
Aug 26, 2010 01:32 PM
bneafus
All Things Towing
Jun 25, 2007 10:02 PM
4x4bigblock
Electrical Systems/Wiring
13
Feb 24, 2006 08:30 AM
