Verify a good ICP SENSOR before chasing any high ipr reading
Good icpv at KOEO is .18-.24 VOLTS
ICP voltage KOEO is .23. Tried cranking tonight, doesn't build any ICP cold much less fire. Pulling valve covers tonight and we'll try the air test again.
You're on the right track.
Check to see if you have any oil in the oil rail after pulling the ICP, if that is how you are testing.
Cold engine might take a few more minutes for the leak to appear depending on the ambient oil temp.
