electrical gremlins help
Old Feb 19, 2017 | 03:25 PM
idi1993f350's Avatar
idi1993f350
trucks a crewcab long bed 93 f350 7.3 idi. I'm having some random electrical issues.
1. glowplugs do not work. new glowplugs, and swapped a extra relay/controller I had and still nothing. it is on a push button set up. I checked the ground for the switch and it is good. no power on any of the 4 posts on the relay. I followed diesel hubs guide. where do I trouble shoot next?
2.starter does not engage. when I tried to jump the fender mounted relay nothing happens. what can I check to trouble shoot? (when key is turned into the start, the dash warning lights flash for a second? such as "wif" "fuel filter" and the others that are there.) this is a new gear reduction starter, that was working prior.
3.when I reattach the batteries, the hazards and headlights flash for a little bit then stop? it goes away after a minute or 2 after having both batteries connected.
Old Feb 20, 2017 | 04:44 PM
7threeaz's Avatar
7threeaz
check all your grounds. Sounds like a bad ground somewhere.
Old Feb 21, 2017 | 11:28 AM
madpogue's Avatar
madpogue
^^^^^ Bad main battery ground or bad main battery + connection. Also, have you LOAD tested the batteries?
Old Feb 21, 2017 | 06:26 PM
7threeaz's Avatar
7threeaz
Also i'll add, don't neglect the cables themselves either. Look for any missing or rubbed through insulation, damage etc.
MK_snipe
22
Apr 22, 2018 01:00 PM
beezf350
Dec 4, 2016 12:46 AM
c_roc16vgli
Jun 17, 2009 03:40 PM
Neatherd
Aerostar
Mar 2, 2008 01:44 PM
red_fordtruck
Nov 9, 2007 03:10 PM
