P0299 while highway driving?
Old Feb 21, 2017 | 10:59 AM
r2millers's Avatar
r2millers
After having mine cleaned by a local shop, 20,000 miles later the unison ring stuck again. I decided to just replace it as I really think the i/s diameter of the new ring is slightly larger, knowing this has been a reoccurring issue for Ford.
You don't list your truck year in your profile, which would help, but here's my Ford parts I used on my 07, plus a Blue Spring fuel regulation kit.
With it apart, I'd spend the extra 150 bucks or so to avoid pulling it apart again soon.
Old Feb 22, 2017 | 01:59 PM
ChalmersP's Avatar
ChalmersP
Might make that a project for this coming weekend. Thanks for the part numbers too, ill double check that everything lines up with my '06.
Old Feb 22, 2017 | 09:11 PM
wheelerg's Avatar
wheelerg
I was waiting for someone to suggest a few full throttle runs. No one has, so I will. I have PO299 at least 1 or 2 times a year. My fix is a steep uphill climb. Full throttle, repeat if needed. I have never cleaned my turbo. Spooling the turbo up to max rpms seems to work.
Old Feb 22, 2017 | 09:28 PM
ChalmersP's Avatar
ChalmersP
Oh come on, its no fun to go WOT... But if you really think I HAVE TO, then I guess I will :/
Old Feb 23, 2017 | 01:28 PM
r2millers's Avatar
r2millers
You will know when the unison ring is truly stuck. No throttle runs can help! Both times mine stuck, it took quite a bit of prying to get that ring loose. It wouldn't move without a couple of big screwdrivers to jimmy loose.
Your method might help if it's just starting to stick from lack of use, idling, or cold/hot cycles.
MoreBoostPlease
Sep 30, 2017 10:29 AM
Sarge261
Jun 2, 2016 12:59 PM
Pittsjock
Jul 2, 2012 04:43 PM
SandR
6.4L Power Stroke Diesel
Dec 27, 2011 06:49 AM
top that
May 25, 2006 12:43 PM
