300 miles from home, problems ...
Old Feb 26, 2017 | 01:20 PM
  #61
dn29626's Avatar
dn29626
I wonder more and more about the UVCH, its connections.
I no longer think it is fuel pressure related, although readings from a pressure gauge would be nice.
Old Feb 26, 2017 | 01:21 PM
  #62
HKusp's Avatar
HKusp
Ranking in order of highest probability of my guess.
1. Bad/loose UVCH connection
2. Bad ICP
3. Bad IPR
That being said, they are all guesses without data. Get with Rich and get it hooked up and see what's going on.
Old Feb 26, 2017 | 01:24 PM
  #63
BigRed1Ton's Avatar
BigRed1Ton
Ditto. The external connections are all tight, no damage, probably original. I haven't seen the internal ones. It might be time to replace them. Burnt out connections inside maybe.
Old Feb 26, 2017 | 01:28 PM
  #64
BigRed1Ton's Avatar
BigRed1Ton
2. Bad ICP
3. Bad IPR
All are good guesses, but I am not eager to throw any more parts at this old truck. The HPOP and IPR seem to be doing what they should, and disconnecting the ICP made it run worse, not better. UVCH is a good guess, but I have no way to confirm or dismiss, unfortunately. I appreciate your input.
Old Feb 26, 2017 | 01:30 PM
  #65
dn29626's Avatar
dn29626
It is time for you to remove the valve covers to check the connections under them.
  #66
HKusp's Avatar
HKusp
I am not suggesting throwing parts at it. I am suggesting getting some data logged and then going from there. everything without data IS guessing.
Old Feb 26, 2017 | 01:31 PM
  #67
BigRed1Ton's Avatar
BigRed1Ton
Have you removed the valve covers to check the connections under them?
No. I just flat haven't had the time or resources yet, to take a look.
Old Feb 26, 2017 | 01:36 PM
  #68
BigRed1Ton's Avatar
BigRed1Ton
Understood. I agree that is needed. I only have Torque Pro, and limited experience. The data I get on the HPOP and IPR seem inline with the norm, but I am no expert. I also see the injector pulse wave looking like it usually does. Beyond that I am out of my depth. Getting short on time, and unfortunately I am too far away from Rich. Too bad, it would be nice to meet the legendary wielder of the mighty Buckzooka . Ha ha !
Old Feb 26, 2017 | 05:20 PM
  #69
dn29626's Avatar
dn29626
What are you driving while the truck is down?
Old Feb 26, 2017 | 05:35 PM
  #70
BigRed1Ton's Avatar
BigRed1Ton
We have 3 other F350's, and a Dodge 1 Ton Cummins to work the ranch. We are hauling hay with the Dodge and two of the other Fords. The third is always hooked to the flatbed trailer, or a stock trailer. I brought my truck over to help, but it went south as soon as I got here.
Old Feb 26, 2017 | 10:22 PM
  #71
Tugly's Avatar
Tugly
UVCH link in my signature will help a ton - so will the OBDII tool link in my signature. My day ran long because of the snow - and it aided in the sabotaging of getting my boat to this side of the state.
Old Feb 27, 2017 | 02:11 PM
  #72
JOHN2001's Avatar
JOHN2001
My first thought was uvch.
Old Feb 28, 2017 | 01:10 PM
  #73
BigRed1Ton's Avatar
BigRed1Ton
Sorry to hear about the boat transport problems. The weather kinda fouled us up here too. It looks like I will be doing the valve cover gaskets and harnesses in the next day or so. Seems like the next step. Guess I might as well check torque specs while I'm there. Is it 120 lb/ft for injectors and 20 lb/ft for rocker arms ? My shop manuals are at home, and I can't remember for sure. I suppose you know the specs for the valve cover bolts off the top of your head ??? Just a wild guess ...
Old Feb 28, 2017 | 04:05 PM
  #74
Tugly's Avatar
Tugly
According to the book (or at least my memory of it), 120 INCH pounds (don't reach for that breaker bar) on the injector hold-down bolts. 240 inch pounds on the rocker arm bolts. Ft/lb torque wrenches do not work on the injectors - they are picky little buggers.
Old Mar 1, 2017 | 10:56 PM
  #75
BigRed1Ton's Avatar
BigRed1Ton
Well, it's definitely not a wiring harness problem ...
