Help 351 won't fire?
Old Feb 18, 2017 | 07:49 AM
skeetseats's Avatar
skeetseats
I have a 351 that won't fire, it's got a new carb, fuel lines, cap, wires, plugs, new brain box on the drivers side. I pulled it out of the garage and it died now won't even try to start on starting fluid? Don't have any help to check spark but I'm assuming that's what it is. I replaced the brain box with no luck?m
Old Feb 18, 2017 | 08:34 AM
ubereal2's Avatar
ubereal2
It would be nice to have another person there to help. But you could take off the distributor cap, and see if the rotor is turning when the engine is spinning. That would at least tell you that the timing chain is still intact.
Have you checked for 12 volts at the ignition coil .
Unk Bob
Old Feb 18, 2017 | 09:22 AM
skeetseats's Avatar
skeetseats
So it's got 10v while cranking but I can't see the cap while turning it over right now. The battery is a bit low but should still fire I would think. The brain box doesn't have to bolt and grounded does it? Also it just pushes voltage to the distributor right? So the box should be good?
Old Feb 18, 2017 | 09:53 AM
good to doo's Avatar
good to doo
Are you sure it is getting fuel? Also you can turn the engine over by jumping the solenoid. And bolt that box down.
Old Feb 18, 2017 | 10:13 AM
skeetseats's Avatar
skeetseats
Ya it's getting fuel, also has new fuel lines and pump. I can see it dumping in the carb. I let it rip with starting fluid without hitting a beat. Bolted the box down and put a new solenoid on it here a second ago and found a blown fuse for eng sol. ? Don't have any of those long ones so I made a shorty work but still no luck
Old Feb 18, 2017 | 10:20 AM
skeetseats's Avatar
skeetseats
OK now I'm confused it's gettino good spark with the plug n wire on sitting on the carb
Old Feb 18, 2017 | 11:45 AM
skeetseats's Avatar
skeetseats
Should I pull the carb and dump fuel directly in? Maybe the carb is clogged from replacing everything. Filters look clean though, you would think it would still fire on starting fluid though right?
Old Feb 18, 2017 | 11:54 AM
good to doo
Why are you using starter fluid? that is for big diesels on very cold days. Stop doing that. If its getting fuel then it must be an electrical issue.
Old Feb 18, 2017 | 12:06 PM
scottscott's Avatar
scottscott
Replace the pickup coil in the distributor.
There are ways to test the ignition system if you have a multimeter. Do a search online for testing the Duraspark system.
Don't remove the carb & dump gas in it.
Pull the plugs & clean them, they are probably gas & ether soaked.
Old Feb 18, 2017 | 01:43 PM
skeetseats's Avatar
skeetseats
I'll give that a shot guys thanks so much for the help. I wasn't sure if I lost prime from swapping the lines, carb, pump, flushing tank out. I only let it run for a minute before I pulled it out of the shop so I thought it list prime and couldn't reach my compressor to push some air
Old Feb 18, 2017 | 06:08 PM
skeetseats's Avatar
skeetseats
So every plug has spark all the way to it. I did figure out one very odd thing... it starts now.... but only with the plug out and grounded? I put the plug back in and won't start. Pull a different one and ground it on the carb and it starts... I did notice it only starts when you let off the key also.. blowing my mind right now
Old Feb 18, 2017 | 06:18 PM
ubereal2's Avatar
ubereal2
Make sure that you engine block is grounded to the body. There should be a ground strap that goes from the back of the intake manifold, straight back to the firewall.
The stock strap should look like this one.
Attachment 206322
On my 79 I have the engine grounded to the body, and to the frame both.
Unk Bob
Old Feb 18, 2017 | 06:24 PM
Tedster9's Avatar
Tedster9
Bad ignition switch can cause this iirc, someone will remember better than I. Symptom is only sparks when going from "Start" to "Run". Aggravating I bet.
Keep in mind that not just any ole' spark will do. It has to be a fat, healthy spark. Orange or reddish won't work, it won't jump the gap when actually installed in the engine and under compression.
An engine that won't start is real rough on all the components, solenoid, battery, starter. If it does finally start, it will then torture the alternator. Put the battery on a charger at let it cook at least overnight.
Old Feb 18, 2017 | 07:25 PM
skeetseats's Avatar
skeetseats
So the ground was bad between the block and firewall so I replaced it with no luck, then started searching for a ground for the frame and never found one. So I ran a ground from the frame to the intake, firewall to the intake, and another off the battery to the intake alone with the one going to the bloco. Still no luck really thought you were on to something haha. I'm going to run a direct ground for the coil?
Old Feb 18, 2017 | 07:28 PM
skeetseats's Avatar
skeetseats
Unfortunately I did by a key switch but didn't come with the ignition like I thought it would. Spark looks great to me it's got one heck of a ark anyways. I'll grab one in the morning if oriellys has them in Stock. Does jumping the solenoid bypass the ignition?
