Help 351 won't fire?
Old Feb 18, 2017 | 10:10 PM
PapaBearYuma's Avatar
PapaBearYuma
Originally Posted by skeetseats
...I did notice it only starts when you let off the key also.. blowing my mind right now
That's almost certainly the pickup coil inside the distributor
Old Feb 20, 2017 | 10:08 AM
skeetseats's Avatar
skeetseats
So it ended up being the ignition switch! Fired right up once I got it swapped out. Now once you put it in gear it doesn't want to stay running, purse like a kitten at idle, could the timing be off? Pretty much the only thing I haven't messed with but it does have a new distributor plugs and wires
Old Feb 20, 2017 | 11:08 AM
Tedster9's Avatar
Tedster9
Suggest you pick up a Shop manual for your truck, there are all kinds of settings and adjustments that makes a big difference on ease of starting and how it runs. Download the setup and instruction sheet for your carb and start from scratch. Make sure the float and fuel level is correct, linkage is correct and use a vacuum gauge to set the idle mixture.
Bondora68
Jan 4, 2019 12:25 PM
mountainsportsman
May 22, 2012 11:43 PM
jetblack06
Dec 7, 2009 07:06 AM
cjben
34
Feb 5, 2005 05:58 AM
helicon
Nov 26, 2004 02:55 AM
