go efi on a fe engine
Old Feb 17, 2017 | 03:44 PM
Björn's Avatar
Björn
has some one allready installed this set on a fe engine
FiTech Fuel Injection
Old Feb 18, 2017 | 11:46 PM
resonateur's Avatar
resonateur
Installed but not run yet. My finish is a long way off. I have researched this unit extensively and look forward to favorable results. It seems that the users who are not as happy, are those using the fuel command center. I decided to run "hard' lines for my fuel supply and return and use an in-tank fuel pump to avoid some of the issues that others have complained about. Compared to a carburetor, reasonably priced and seems well engineered so far.
Old Feb 19, 2017 | 03:47 AM
Björn's Avatar
Björn
hard lines are better then the rubbers ones
And will the The 40005 Fuel Delivery Kit includes a 255 L/PH inline external fuel pump then work better ??
Old Feb 19, 2017 | 09:18 AM
resonateur's Avatar
resonateur
Bjorn:
I don't think there's any difference between steel and rubber fuel lines. They sell a kit that includes the flexible fuel lines, and they certainly would be easier to install! I believe the kit has an external in-line fuel pump as well. I wanted to run an in-tank pump as it is quieter, more efficient and no issues with pump mounting relative to fuel tank height. In-tank pumps push fuel, in-line pumps suck (so to speak). That was just my preference and, since I was installing a new tank anyway, just as easy.
Old Feb 19, 2017 | 11:39 AM
Björn's Avatar
Björn
some good info
I wanne place a gas tank under the bed , so the only thing is then to have a good pump
Yuriy Fomin
18
May 19, 2019 10:40 AM
gprust
May 8, 2017 03:10 AM
honeydew
Jan 26, 2013 10:43 PM
78 Ford F150 460
17
Jun 24, 2012 11:31 PM
FarmallFan
Sep 11, 2002 10:19 PM
