Bouncing speedo
Old Aug 29, 2003 | 10:04 AM
mchild's Avatar
mchild
Bouncing speedo
I have a 1985 F350 2wd with T19 4 speed. The speedo had not worked since getting the truck and the other day I pulled the speedo cable at the trans to fix it. I found the gear severely worn and thus replaced it. While I had the cable out of the trans I check that it wasn’t broken by attaching the cordless drill to it. While I ran the drill my wife confirmed that the speedometer was working.
But, now that I have it all hooked up with a new cable gear the speedometer bounces a lot and reads low until the truck reaches about 60 mph. It did not bounce when I ran it with the drill so there must be something in how it is being driven by the trans gear that is causing it to bounce and read low. Any ideas?
Many thanks,
Mark
Old Aug 29, 2003 | 08:00 PM
Taynton1's Avatar
Taynton1
Bouncing speedo
When ever mine bounces it generaly means it's binding and will break soon. Try a new cable they are not too expensive. The drill has a lot of power compared to that little gear.
MT
Old Aug 29, 2003 | 11:41 PM
Stingray42's Avatar
Stingray42
Bouncing speedo
grease the speedo cable
Old Sep 2, 2003 | 08:57 AM
mchild's Avatar
mchild
Bouncing speedo
Okay, how is the best way to lube a cable?
Old Sep 2, 2003 | 10:48 PM
kspilkinton's Avatar
kspilkinton
Bouncing speedo
Can't answer about the lube job, but I know that I had to check the speedo cable at both ends to find my bouncing problem. The speedo cable had pulled partially out of the speedo. Also if you have cruise, check all four ends, as the speedo goes through the speed sensor diaphragm before reaching the tranny or speedo.
If it works while you're spinning the speedo cable with a drill, you've got something else at the tranny end wrong, and the cable doesn't need a greasing, as it works just fine for your test. If it was binding it would have snapped with a drill spinning it.
-Kerry
Old Sep 14, 2003 | 02:20 AM
Gabby's Avatar
Gabby
Bouncing speedo
Lubing cable is relatively simple but a pain in the butt...take a small ziplock back, pop a hole in the lower corner, slip top end of cable thru hole and wrap a rubber band around it several times to seal the bag to the cable, pour a small amount of lube (gear oil should work or a thick oil and let it drain down thru the cable....used to do that of motorcycle brake cables all the time...work slick as $#@%..Good luck
forddieselnewb
21
Dec 28, 2012 10:54 PM
64fordf100292
Sep 16, 2007 07:20 AM
gangstakr
Jun 21, 2006 09:38 AM
gl0116
Oct 27, 2004 03:02 PM
mchild
Aug 31, 2003 12:35 AM
