The $500 IDI adventure
#31
If I drive it, warm it up, shut it off and wait anywhere from zero to 30 minutes, it starts up pretty easily. If I wait a couple hours, it takes a few tries to get it to fire and run. No starting and dying symptom. Just excessive cranking and multiple cranking attempts.
#34
Didn't get around to testing the glow plugs yesterday or today, but I will tomorrow. I did however, fully drain and flush the engine block, and refill with the proper coolant. All that was in there was straight water, unfortunately. I caught it in time though. I washed and scrubbed all the filth off it while I was working on it, too.
List of things that don't work:
left turn signal
rear tank (starves and dies when selected)
brakes (need bleeding + vac pump)
fuel gauge
horn
parking brake
left turn signal
fuel gauge
horn
parking brake
#35
#36
#37
#40
think about deleting the front tank, and installing a rear 38 gallon tank,
you can get em on e-bay for 100$ delivered, comes with mounting hardware and copper tube to extend your pick up.
then you can delete the problematic fuel switch valve.
this mixed with a new showerhead, and your fuel problems will be solved.
#41
#42
#43
#44
More work on the truck. Tightened the return line from the fuel filter, and I will see if that fixed my air intrusion issue that came about after my $35 IP replacement. Welded up a new muffler, a 31" glasspack, which coupled with my IP turned up 1 flat made it run damned good! I mounted a small switch panel and a light bar to the front. I kind of always thought light bars were for silly highschool kids to put on daddy's truck but this one was free and actually is pretty nifty!
TraderJ
10-07-2009 05:17 PM
Rockies
02-05-2004 11:46 AM
