Not getting fuel
Old Jul 18, 2015 | 03:18 PM
joboy's Avatar
joboy
Not getting fuel
I have an 83 F350 6.9 IDI
It just died and wouldn't start. Replaced lift pump. injection pump replaced three years ago. Bypassed fuel/water separator -a year ago. Not getting fuel-not sure of where to look. Nothing comping our of bleeder valve on fuel filter.
Old Jul 18, 2015 | 03:41 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
hook up the lift pump so it draws out of a jug of diesel.if it picks it up then the new lift pump is good and the line to the filter isn't plugged up.
then you'll know to look at the fuel line from the tank selector valve (it might be bad) or the pickup in the tank.
first make sure you've got half a tank of fuel.if she's below 1/4 tank it could be a tank pickup issue.
Old Jul 18, 2015 | 03:44 PM
speedwrench72's Avatar
speedwrench72
you must confirm that it is a fuel problem, are you certain the glows are working?? it is not likely the fuel system will break when you shut it off. its more likely some thing wrong with glows..be careful not to over heat the starter...
Old Jul 18, 2015 | 03:53 PM
joboy's Avatar
joboy
things done
the truck unfortunately is an ether baby at least for now. When I switch the tank selector I get two different readings so that's ok I think. I can try to pull fuel from a container as suggested. The lift pump is brand new.
Old Jul 18, 2015 | 06:58 PM
madpogue's Avatar
madpogue
How much fuel is in each tank?
Old Jul 19, 2015 | 10:53 AM
Macrobb's Avatar
Macrobb
The rubber filter cone can fail inside the tank, meaning that you will start sucking air at 1/4 tank or so.
Old Jul 19, 2015 | 09:49 PM
Bob Shumway's Avatar
Bob Shumway
I would recommend dropping the tanks to fix the cone of doom and switch to manual ball valves while you have the truck off, then you never have to worry about the tank switch getting stuck and leaving you stranded, it is one of the single best mods I have done to my truck, I would do it on any new ones I buy before making them daily drivers.
Old Jul 22, 2015 | 06:24 PM
joboy's Avatar
joboy
I am trying to determine if the lift pump cam lobe is worn. I need a diagram -anyone know of a diagram of the lift pump cam? All other things check out -plenty of fuel in the tanks, etc.
Joe
Old Jul 22, 2015 | 11:33 PM
madpogue's Avatar
madpogue
What kind of diagram of a cam lobe would you be looking for? It's a lobe on the camshaft. Not sure what else there is to know about it. It's harder by a long shot than the arm on the pump, so the engine would likely have to have several million miles on it, over dozens of replacement pumps, to show wear.
Old Jul 23, 2015 | 12:49 AM
Macrobb's Avatar
Macrobb
Yup; that's one part that is not going to fail on you. The pump, on the other hand... mechanical fuel pumps are cheap and fail frequently.
FordAnne
Nov 11, 2017 11:03 AM
mountain dewd
44
Mar 16, 2017 11:55 AM
dirtboss
Nov 11, 2016 05:53 PM
altruego
May 17, 2011 04:04 PM
Rockies
Feb 5, 2004 11:46 AM
