Cracked Frame
Old 02-14-2017, 02:44 PM
gannonm's Avatar
gannonm
gannonm is offline
Cracked Frame
Hi guys,
I'd been noticing an interesting problem with my 95 F-150 4x4. When I'd back up the wheels would get a toe-out and the tires would start squealing. It would get better when I was driving forward. After replacing all the steering linkage and doing the right side axle pivot and radius arm bushings, I noticed that the frame was cracked where the axle pivot bracket attaches to the under engine crossmember. What are my options, to weld the frame back together or just put in a new crossmember?
Thanks for the help,
Gannon
Old 02-14-2017, 05:19 PM
kermmydog's Avatar
kermmydog
kermmydog is offline
Try welding it.
At worse case you can buy a crossmember.
Old 02-14-2017, 07:26 PM
stak's Avatar
stak
stak is offline
weld the cracks / grind it off then put another plate over the crack and weld it.
Old 02-14-2017, 07:48 PM
BeholdenZippy's Avatar
BeholdenZippy
BeholdenZippy is offline
It's hard to tell from your pictures, but is the frame cracked or the just the cross member under the engine?
josh86ford
15
05-22-2009 06:14 AM
cyclospot
02-26-2008 01:39 AM
rmojo12
1978 - 1996 Big Bronco
09-12-2004 03:05 PM
cryptonik420
05-26-2004 12:15 PM
jniolon
04-12-2002 11:19 AM
Quick Reply: Cracked Frame
