I need shocks
Old Feb 13, 2017 | 02:21 PM
brian1080's Avatar
brian1080
I need shocks
Where can I get shocks that will fit my 6" lift??? I ordered the ones on bronco graveyard that are the length I need, but they mailed me saying they are on backorder for an unknown time and apparently they cancelled my order completely since I got my money back today. 😡
Now I need to find shocks that will work, but finding any the right length is not easy. Anyone have any input?
Old Feb 13, 2017 | 02:23 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by brian1080
Where can I get shocks that will fit my 6" lift??? I ordered the ones on bronco graveyard that are the length I need, but they mailed me saying they are on backorder for an unknown time and apparently they cancelled my order completely since I got my money back today. ��
BDS, Skyjacker, Rough Country Rancho, Superlift....
I'd visit or contact Rocky Mountain Suspension Products outta NC: Rocky Mountain Suspension Products - Leveling Kits, Lift Kits, Block Kits, & Off-Road Suspension
Click on Shocks and then select the brand. In the next screen will be a search box for your application. EZ.
Old Feb 13, 2017 | 02:26 PM
brian1080's Avatar
brian1080
It's not so easy. My truck uses springs from other trucks, axles from an f350, etc. it's not just a typical 6" lift.
Old Feb 13, 2017 | 02:43 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I know the springs you are talking about, I bet you will not get that much flex. Fork lift/backhoe/tractor or twist ditch drop and measure full compression and full droop and order from who ever has in stock that will work.
Checked here, its next door.Truck Parts & Truck Accessories in Overland Park, KS 66209 FYI Chris is really busy today.
I'd bet some for a 6" would work.
Shocks by Application | Superlift
Old Feb 13, 2017 | 02:48 PM
HIO Silver's Avatar
HIO Silver
Um..... you should have communicated that in your original post. We're not clairvoyant.
Measure full droop and full compression... then look for a shock that is 60/40 or 40/60 depending on the planned use of your customized truck.
Old Feb 13, 2017 | 02:51 PM
krazyness's Avatar
krazyness
Theres always fox shocks as well. Can order those for pretty much anything.
Old Feb 13, 2017 | 02:55 PM
brian1080's Avatar
brian1080
I have basic measurements, I just can't find a site that lets me find shocks based on length
Old Feb 13, 2017 | 03:13 PM
77&79F250's Avatar
77&79F250
Pro Comp compression and extension measurements are on it. http://www.4wheelparts.com/eSearch.a...rs?N=1frZ17y7f Scroll down a bit to get the Pro Comp measurements.
Skyjacker H7002 – Hydro Shock Absorber 15.69 in. Extended; 10.02 in. Collapse. Their site has the measurements if you click on each shock. Yes PITA.
Old Feb 13, 2017 | 03:45 PM
brian1080's Avatar
brian1080
Ok, I'm on the right track now. Apparently mobile version is way watered down, on the computer I have a lot more info. I'll see what I can find.
av8ng2000
May 28, 2011 10:19 PM
scatgo
Offroad & 4x4
29
Feb 21, 2011 04:46 PM
pdqtimetrialer
Apr 26, 2010 07:18 PM
checkered02v10
Jul 2, 2007 06:40 PM
JoeB
Dec 26, 2001 05:29 PM
