Taking My Time
Old Feb 12, 2017 | 06:12 PM
vancouverbrian's Avatar
vancouverbrian
Taking My Time
I have been lurking on these forums for a while but this year (likely May), I will be ordering a F350 (but would consider a 250), gas (6.2), Lariat (w/o ultimate), crew cab, long box, 3.73 axle. I am going to use it to tow a 5th wheel (about 10,000 lbs GVWR) in the winter to the southern US for the winter.
Features I am planning to order...blue jean, 4x4, SRW, 5th wheel prep, LED clearance lights, extra extra alt, remote start, tailgate step, 40/console/40 seats, navigation, uplifter switches, trailer tow camera package, spray bed-liner.
The trailer tow rating is 12,000 lbs for 5th wheel. I should be good with this configuration.
If anyone wants to give me some advice before I order it in a few months, I would appreciate it.
BTW, I have learned lots from your posts here. THANKS
Old Feb 12, 2017 | 06:15 PM
bronc71's Avatar
bronc71
Welcome
Go with the 4:30 gearing if nothing else you get for info on here you will not regret it!
Old Feb 12, 2017 | 06:20 PM
Siriustoo's Avatar
Siriustoo
Do you know the hitch weight of the fifth wheel you are interested in? It is normally around 20% of the weight of the trailer. This seems to be the limiting factor in 5th wheel selection.
Old Feb 12, 2017 | 06:28 PM
vancouverbrian
The dry weight should be around 8000 and GVWR will be about 10000. I have yet to buy it. There are several in this range that I am considering. Tongue weight should be around 15% (say 1500lbs) and the payload capacity is 3300lbs from the spec sheet.
Old Feb 12, 2017 | 06:29 PM
MagneticTiger's Avatar
MagneticTiger
Go with the 4.30 axle. It will be better for towing with the gasser. Also, I recommend Linex over the Ford liner. The Ford liner isn't prepped properly, and therefore, an inferior product, assuming the Linex is installed correctly.
Otherwise, nice build!
Top_Speed1's Avatar
Top_Speed1
Sounds like you have a good plan, Brian. I sure can't blame you for wanting to snowbird south, my wifey has about the same plan in mind.
Glad you're not a lurker anymore
Old Feb 12, 2017 | 06:32 PM
ATP Pilot's Avatar
ATP Pilot
get the 4:30 axle...see my signature...next one will have the 4:30 gear.
Old Feb 12, 2017 | 06:34 PM
vancouverbrian
thanks guys. I have about 2 years to full time retirement and am a single guy. Planning to buy a nice 28 to 29 foot 5th wheel. Next winter if I have this done, will go away for a couple of months to try it out. Just a question, why go with a 4.30 axle if don't need the towing capacity? I know it increases gas consumption, but more power for towing. Do I need to do it?
Old Feb 12, 2017 | 06:36 PM
MagneticTiger
Well, I understand that the MPG difference is marginal. Because of that, I recommend getting the most power to the wheels as possible. Being that you are getting gas, I would definitely go with the 4.30. It will be much quicker, make towing a breeze, and improve the smiles per dollar factor of your truck.
Old Feb 12, 2017 | 06:41 PM
RainDesert's Avatar
RainDesert
thanks guys. Just a question, why go with a 4.30 axle if don't need the towing capacity? I know it increases gas consumption, but more power for towing. Do I need to do it?
Town driving and towing mpg's are higher with the 4.30 vs 3.73. 3.73 is better for unloaded freeway driving. Towing in the 10k range, yes you should do it(4.30's).
Old Feb 12, 2017 | 06:43 PM
bronc71's Avatar
bronc71
It just seems that even all around the 4:30 just works really good with the gas motor. In town economy seems to be better,non towing Hwy will be a bit worse, towing will be superior in performance and mpg
Old Feb 12, 2017 | 06:46 PM
mhoefer's Avatar
mhoefer
For what it's worth, I recommend you add the fifth wheel prep, the extra cameras, the 360, it will come in handy hitching up and parking the truck.
I recommend going with the F350, add the camper package and you get overload springs, and a rear sway bar. This improves handling when towing. I have had it on three new F350s.
Once you get a F350, you don't limit yourself with the pin weight like a F250 can. It will open up options on the trailer you can choose.
Depending on the trim level you want, consider the LED lighting package if you can get it.
I pick all these items because you want to be able to keep a truck a long time and not having to keep trading it open for sake of something that now need.
Consider a crew cab too, but that is another story.
Hence why have my third F350 crew long box with fifth wheel prep.
Old Feb 12, 2017 | 06:47 PM
hmcfly's Avatar
hmcfly
When I got mine
Old Feb 12, 2017 | 06:49 PM
bronc71's Avatar
bronc71
Originally Posted by hmcfly
When I bought my F-250 Diesel it came with a 3.31 locking axle and the high capacity tow package, I guess that is why mine is low.
Not sure where your going with this post?
Old Feb 12, 2017 | 06:52 PM
vancouverbrian
I am choosing a crew cab with the trailer camera package which is 360 with the CHMSL camera for 5 th wheel. The LED headlights option is $1200 cdn and then must add BLIS for a total of about $2000. Seems kind of expensive. I would like it but must limit what I choose. I had not thought of the camper option but it is only about $140 more. Seems like a good idea. Now you understand why I asked for advice from present owners.
