64 F-500 engine
Old Feb 12, 2017 | 03:45 AM
bart f-350's Avatar
bart f-350
64 F-500 engine
Hello Guy's,
I'm new to these years F-500, and I've seen one interesting.
whit which engines did they come?, and is there a preferred engine for this series?
The ad says it has a 200CUI 6inline.
are there any other points to look for when I want buying one?
Thanks in advance,
Old Feb 12, 2017 | 12:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bart f-350
I'm new to these years F-500, and I've seen one interesting.What
The ad says it has a 200 CUI 6 inline.
Impossible!
200 I-6 introduced in 1964, was never installed in any truck. Installed in compact/mid-sized passenger cars thru 1983.
1964 F500 could have a 223 or 262 I-6; 292 2V; 330 2V Medium Duty FT engine; 330 2V Heavy Duty FT engine. 361 2V & 391 4V also available but rarely installed in an F500.
The 4th digit of the VIN is the engine code, post what it is.
Old Feb 12, 2017 | 12:22 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Hello Guy's,
Thanks in advance,
If you can get a picture of the warranty plate then it will have many details about how the truck was originally equipped. I always make sure a seller sends me a picture of the warranty plate before even considering a vehicle.
Old Feb 12, 2017 | 12:48 PM
bart f-350's Avatar
bart f-350
Ok, I'll see if I can get that pic.
@Nd, I already thought that was a small motor for a 500.
but please enlighten me, what does the 2V and 4V in the other type of engines mean?
And another question, would there be anybody so kind to me to explain me how they moved all that weight in the days, only with such (relatively) small engines?
I also have a US pick-up, with a 318 V8, and that one has already "difficulty" with a 2.5 metric tonnes trailer behind!?
Old Feb 12, 2017 | 12:57 PM
raytasch's Avatar
raytasch
Believe Nothing
Not Bill, he may be gone for the day, but I'll throw up the answers.
The V designation is the number of carburetor venturi, otherwise referred to as barrels of the carb. One barrel, two barrel or four barrel, 2V or 4V.
They used a lot of gearing ratio to move the weight. It did not move fast but the lower power got the job done with gearing.
Who was it, Archimedes, who said, "Give me a lever long enough and I will move the earth." It is all about mechanical advantage, gearing.
Old Feb 12, 2017 | 01:48 PM
bart f-350's Avatar
bart f-350
Thanks Ray,
So If I'm correct, the heavy haulers of the day (say F-400 and up?) are not the fastest, (as you might know, I'm new to this era of trucks) but can they keep up with modern day traffic?
And I also heard that there is such a thing as a Two speed rear axle, can somebody tell me please how that is used?
Old Feb 12, 2017 | 03:10 PM
bart f-350's Avatar
bart f-350
this should be the 200cui??? that the owner sended.
I asked him also to sent a pic from the datatag at the doorsill.
Old Feb 12, 2017 | 03:13 PM
NumberDummy
this should be the 200cui??? that the owner sent.
Absolutely not! No 200 I-6 of any year has a valve cover like this. It's probably a 223 I-6.
1963/79 Warranty Plate riveted to the left door face below the latch.
Pic: Here's an example of a 200 I-6. Notice that the intake manifold is made as part of the cylinder head.
Old Feb 12, 2017 | 07:21 PM
tinman52's Avatar
tinman52
Welder User
It appears to be a 223 engine....would need to see more pics to confirm 100%.
It has the early style valve cover(54-59), so it probably has been swapped in at some point.
Old Feb 12, 2017 | 07:59 PM
raytasch's Avatar
raytasch
Believe Nothing
Thanks Ray,
The short answer is no, they can not keep up with modern day traffic, at least long term.
The final drive ratio is possibly in the 5:1 to 7:1 range. Depending on tire size, the engine will spin quite high. Find the rear end ratio, figure circumference of the drive axle tires, locate one of many engine speed calculators on line and you can get an idea what your engine will spin at various road speeds.
Most two speed rear ends are high ratio and higher.
Old Feb 13, 2017 | 12:50 PM
bart f-350's Avatar
bart f-350
Ok Thanks, I was wondering if I could use such a truck for travelling.
clockmaker
Aug 18, 2012 06:22 PM
110Dave
Large Truck
15
Oct 29, 2009 08:12 AM
SNEWTON
Feb 2, 2009 05:05 PM
Still in the 60's
Oct 22, 2005 09:35 AM
rv21350
Mar 22, 2003 08:16 AM
