What Engine
Old Mar 21, 2003 | 04:17 PM
rv21350's Avatar
rv21350
What Engine
I have a 58 F100 donor pickup that has a v8 engine. The exhaust manifold runs in front of the engine from one side to the other. What engine do I have.
Old Mar 21, 2003 | 07:04 PM
Kenny's Avatar
Kenny
What Engine
Hi,
Sounds like one of the originally equipped Y-block V-8's.
There were mainly two, but actually three different V8engines used for 1958 model year light duty truck.
The early 1958's came with a 272 V8.
About mid-production year, they switched to the 292 V8.
During this change, When supply shortages of the 292 occured, some 312's were installed.
All three of these engines shared the same block.
The 4th character of your truck's vin number is the engine code and will tell you what you have if original.
L = 272
C = 292
I hope this helps.
Old Mar 22, 2003 | 08:16 AM
rv21350's Avatar
rv21350
What Engine
Thanks for your help, I should be able to find out.
Thanks
Randy
