Paint and Body Work Question...
Old Feb 11, 2017 | 04:06 PM
ktgovols's Avatar
ktgovols
I'd like y'all's opinion on paint and body work and reassembly.
I had originally gotten it in my mind that I would do all my body repair and then paint each piece individually prior to setting the cab back on the frame and then build everything out.
A second option I've considered as I've worked thru my upper and lower fenders and front end is if I shouldn't paint the undersides of everything , then reassemble the parts work the body smooth, then paint the exterior surfaces. I ask this because the fenders are flimsy and never in their final shape until they are bolted together.
Or a third option would be to build the body on the frame, work everything smooth, then take it all back apart, paint it, then reassemble it.
I'm leaning towards the third option but I was wondering how y'all would do it or how you did it time was not an issue to you. I'm looking for your lessons learned. I think I'll be at that decision point in a few months.
Thanks
Keith
Old Feb 11, 2017 | 04:39 PM
rico56's Avatar
rico56
Hi Keith,
I'd highly recommend option number three. Maybe number one, if all the parts are the old ones and the body works were minor things. In my opinion, option number two is not an option at all.
Old Feb 11, 2017 | 09:18 PM
tinman52's Avatar
tinman52
Welder User
Yup, #3. If you can't do that, you can also make some fixtures to hold the panels in their correct shape. I do this alot, you can easily work around all sides.
Do all the body work first before painting anything, if you can.
About painting......are you using a metallic color, or a solid? It can make a difference on how you paint it.
Old Feb 11, 2017 | 09:44 PM
RingoRaintree's Avatar
RingoRaintree
[IMG]https://cimg9
3rd option is working for me. I've got the time and can be real careful during final assembly. Bonus is the the fiddly little alignment problems are worked out.
Old Feb 12, 2017 | 11:54 AM
ktgovols's Avatar
ktgovols
I plan to paint a solid color.
Old Feb 12, 2017 | 02:40 PM
petemcl's Avatar
petemcl
IMHO if you haven't changed any structural components on the frame or body that would effect the way parts fit then #1 will work. Otherwise #3 is best. I don't like #2 because you can never get paint into all the cracks and seams.
Old Feb 16, 2017 | 08:10 PM
Outlaw56's Avatar
Outlaw56
Solid Color, Number three for sure. Metallic, game changer if your new to painting and doing it yourself.
Highboy74
Paint & Bodywork
Sep 13, 2016 09:07 PM
cdrmotorsports
Jun 12, 2009 08:12 PM
racoonbandit
13
Sep 13, 2006 11:38 AM
Bigmonts
Tennessee Chapter
Aug 20, 2006 11:04 AM
Rick32
1997 - 2003 F150
Apr 19, 2006 02:45 PM
