Body Side Molding Repair
Has anyone had the paint flake off their body side moldings on the doors? Mine have seen better days. What should I do? Remove the moldings and get alll the 3m tape off? Take them to a body shop to get painted? Get aftermarket ones? What should I expect to pay to have them removed, painted, and put back on?
Once you pull them they never seem to be the same. They're quite flexible. I'm sure a good body man (not me) could pull them off, paint them and put them back on. Not sure what to expect for cost but I'd say the job is about a 6 hour job total.
I removed mine altogether due to fading and paint chipping. Getting the tape residue off was the longest part of the ordeal.
The tape on mine was starting to let go so I pulled them off, cleaned everything off, re 3m taped them and put them back on. The started coming off again about 2 weeks ago so I pulled them off. The truck looks good without them. My truck had a build up of wax residue around the ends that required quite a bit of work with buffing/rubbing compound to remove but after that the paint looks exactly the same as the rest of it. I can get a pic of it if you want.
I repainted mine two weeks ago , on the truck!, I got a roll of the blue masking tape,slid it behind the moulding,taped top/bottom/and ends,then put newspaper about a foot on each side of the tape and also extended it over the running boards , wiped it down with wax and grease remover , lightly scuffed it up with fine sand paper, wiped it down with wax and grease remover again,then 3 light coats of paint, followed by two coats of clear,the thing thats interesting about it is the paint I used is the Duplicolor Autozone sells in the spray cans!,it looks and matches great,
after looking at the mouldings the way they were for the last 3 years I
should have done this years ago!, If I can do this ,anydody that has a afternoon and a garage (to keep the wind down), can do this!!
I repainted mine two weeks ago , on the truck!, I got a roll of the blue masking tape,slid it behind the moulding,taped top/bottom/and ends,then put newspaper about a foot on each side of the tape and also extended it over the running boards , wiped it down with wax and grease remover , lightly scuffed it up with fine sand paper, wiped it down with wax and grease remover again,then 3 light coats of paint, followed by two coats of clear.
The thing that's interesting about it is the paint I used is the Duplicolor Autozone sells in the spray cans! It looks and matches great!
After looking at the moldings the way they were for the last 3 years I
should have done this years ago!, If I can do this, anybody that has a afternoon and a garage (to keep the wind down), can do this!!
