I'll start off by saying I don't know much about Fords I have always been a Chevy and Mopar owner. I have a 93 F150 with I'm assuming a 5.8 in it as that's what is on the intake, the guy we bought it off of said he rebuilt it and it was a 5.0.
We got it at a decent price as we needed something to drive and the guy said he rebuilt the motor the could never get it to run right so that is why he sold it. When you first start it you have have to hold the accelerator to the floor then you have to keep it running for a couple of minutes before it will idle on its own and its the same way even when it's warmed up. When it is running it runs real ruff, it has all new plugs wires and everything and that didn't make a difference. I think it might be a tooth out of time. Does that sound correct to anyone?
Thanks for any help and if you need any other info let me know.
Is the 5.8 molded into the lower intake manifold? If you have a 5.8 and the guy that rebuilt it thought it was a 5.0 he would probably have gotten the spark plug wires wrong as the firing order is different between the two engines.
It would be a good idea to check the timing also to see if maybe the distributor could be a tooth off as you suspect. A few things to sort out to begin with.
Where would I look to see if 5.8 is molded into the lower intake? I have looked for it but not found anything so I might not be looking in the correct place.
I'm just going by what you quoted. Granted you didn't say it was molded. I know my '94 with the 5.8 has it molded somewhere in plain sight, I think it's on the passenger side valve cover. I will have to look here in a bit.
At any rate you will need to determine which engine you have. Probably the best way would be measure the distance between the valve covers. The valve covers are 2 inches farther apart on a 5.8.
I was wrong it is molded into the upper intake in very plain sight standing on the passenger side of the engine.
I also have a 1990 F-150 with a 5.0 and the 5.0 is also molded into the upper intake in plain sight standing on the passenger of the engine.
I was going to measure the distance between the valve covers, but that is a daunting task with all the junk on these things.
I have the 5.8 then that's what is molded into the top of the intake. So now I guess my first easy step would be to make sure the firing order is correct and all the plug wires are on correctly since the guy said it was a 5.0.
Now I just need to find a diagram showing me both of these and I can check that out and hope that it is just a messed up plug wire problem.
Now I'm wondering if it's possible to interchange the upper intake manifolds between a 5.0 and a 5.8. One wouldn't think so beings they have the numbers so clearly molded into the upper intake manifold. Does anyone here know? ANYBODY HERE KNOW??
Does anyone know if this is possible? I would like to get the running issue figured out as I'm sure its in the timing someplace.
